RWD Civic info and suggestions needed.
Old Dec 18, 2004 | 05:54 PM
Pony's Avatar
Default RWD Civic info and suggestions needed.
i have a 97 hatch chassis that i could use, but id rather take my chances with a 96+ coupe just because theres more for me to fab on. instead of the S2000 motor id rather use a B18C
however, what would it take besides a 4 link rear suspension to make a civic rwd. i understand all the obvious stuff like custom driveshafts and all. so what tranny could i use? i want something simple and dont plan on putting a TH350 onto a b motor or anything silly. i just want a good, rwd street car that i can take to the drags or do some drifting passes with.
someone help me out. im open to any theories, suggestions or comments.
Old Dec 18, 2004 | 07:17 PM
drdisco69's Avatar
Default Re: RWD Civic info and suggestions needed. (Pony)
My honest suggestion is get a RWD car. A RWD civic is probably going to make a shitty drifter anyway. An AE86 or a 240 would make things a lot easier. Just think of the bullshit of mounting a FWD motor in a RWD configuration, too. Then what trans to use, what rear end, where to mount the suspension to the body, etc.
I love RWD, I have an 86 Corolla that I have plans to put an SR20 in. An SR20DET is capable of 400+ whp with only bolt-ons and turbo upgrades, something that can't be said for a honda motor.
I'd like to hear some other suggestions, but for my money, it's a lot easier to start with a well designed RWD car instead of trying to make your own out of something not intended to be one.
Old Dec 18, 2004 | 07:42 PM
MolecularIntegra's Avatar
Default Re: RWD Civic info and suggestions needed. (drdisco69)
Gonna have to agree here. If you just want a fun street car that's RWD there's so many options out there that make more sense than a Civic project. If you're really set on it then go ahead but go all out man. If you go through with all that and end up with a <200whp b-series motor it's not gonna be worth it. And no offense but you're not gonna find anything worth while on HT except the couple huge threads on RWD projects.
Old Dec 18, 2004 | 07:45 PM
Pony's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">My honest suggestion is get a RWD car. A RWD civic is probably going to make a shitty drifter anyway. An AE86 or a 240 would make things a lot easier. Just think of the bullshit of mounting a FWD motor in a RWD configuration, too. Then what trans to use, what rear end, where to mount the suspension to the body, etc.
I'd like to hear some other suggestions, but for my money, it's a lot easier to start with a well designed RWD car instead of trying to make your own out of something not intended to be one.</TD></TR></TABLE>
not hard to make my own motor mounts. id probably use the rear end off of an S13. id probably have to do a 4 link to mount suspension. but in actuality, i dont want a 4 link rear suspension.
Old Dec 18, 2004 | 07:50 PM
drdisco69's Avatar
A 4 link isn't bad, but it's far from ideal. The S13 rear end would be good, too. What are your plans on the motor mounts, as there's not much to mount to on the sides of the motor. I was trying to think of a way to do that a few weeks ago.
Old Dec 18, 2004 | 09:03 PM
dfoxengr's Avatar
look in the drag forum theres a guy with a ge2 integra doing s2000 rwd
Old Dec 19, 2004 | 10:48 AM
suckawillis's Avatar
Default Re: RWD Civic info and suggestions needed. (hybridvteceg)
grip drift
Old Dec 19, 2004 | 03:55 PM
techer's Avatar
dont the B series spin the wrong way to go front engine rwd with any sort of ease?
Old Dec 19, 2004 | 04:16 PM
HONDA_TYPE_R's Avatar
Default Re: RWD Civic info and suggestions needed. (techer)
Check out the fabrications forum HT member RaceCity USA is doing an RWD DC Integra with an H22A. By far the most well written article I have seen on here.
Old Dec 19, 2004 | 05:07 PM
Pony's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">look in the drag forum theres a guy with a ge2 integra doing s2000 rwd</TD></TR></TABLE>
id just hate doing the S2000 motor and tranny.
Old Dec 19, 2004 | 05:12 PM
dfoxengr's Avatar
why
Old Dec 20, 2004 | 07:32 AM
Pony's Avatar
ive got parts coming out of my *** for b series. S2000 stuff, id have to hunt down.
Old Dec 20, 2004 | 07:47 AM
dfoxengr's Avatar
oh i just thought u meant u wouldnt want to use that motor.
Old Dec 20, 2004 | 07:26 PM
Pony's Avatar
well, i know b series like the back of my hand. k motors are still like reading spanish to me. i can read it, but i really cant put it all together like i could english.
b series' do spin the wrong way. however, me and st00pid talked it over and theres ways around it to make the motor spin clockwise. something like grinding cams to make it flow for clockwise spinning, dry sumping the oil and using an electric water pump. but then again, maybe ill use a k motor after all. i still have to start getting the chassis ready anyways so ill have time to think about it.
Old Dec 22, 2004 | 03:51 AM
Why not just put the K motor in the back facing in the same direction it faces up front??? Have a header custom fabbed (majorly) and an exhaust too. It's early and I may be neglecting some key points, but those are my thoughts on the K setup.
JDMaccordcb7
Apr 18, 2023 06:05 AM
Diller
Dec 27, 2011 08:42 AM
SoullessJapaneseMachine
Suspension & Brakes
Oct 25, 2006 11:12 PM
91SR
Apr 24, 2005 10:50 AM
marques4130
Dec 5, 2003 02:47 PM
