obd1 swap into a ek
Old Dec 18, 2004 | 04:19 PM
s2000june's Avatar
Default obd1 swap into a ek
im just wondering if anyone can tell me all the sensors on a obd1 dohc block and a obd2 block only one that comes in mind that is not on obd1 but on obd2 is the knock sensor other than that im not sure. im trying to put a obd1 b16 block into my 00 ek but i wanna make sure everything plugs up so i wont throw codes but i know imma have to wire a knock sen. is there anything else im forgetting? any forums with this info? thanks for the help
bump for NJ
Old Dec 18, 2004 | 04:20 PM
chad's Avatar
Moderator
Default Re: obd1 swap into a ek (civicrida3)
knock is also an obd1 sensor....
lots of obd2 have different connections than obd1
Old Dec 18, 2004 | 04:32 PM
s2000june's Avatar
Default Re: obd1 swap into a ek (chad)
hmm. well im only concerned with the bottom end cause i got a obd2 head. but i just wanna make sure i can completely use my ex harness with the obd1 bottom end i just wanna know if theres gonna be extra sensors from my harness that wont plug up to obd1 block and make me throw codes. i will run a chipped p28 meanwhile but for inspections i need to change back to p72 so i can pass. lemme know guys. thanks for info chad
Old Dec 18, 2004 | 05:28 PM
hatchi's Avatar
how bout ckf crank fluctuation sensor.
Old Dec 19, 2004 | 04:16 AM
s2000june's Avatar
Default Re: obd1 swap into a ek (hatchi)
is that one? lol im asking you guys
thanks bro anymore
95civicproject
Sep 5, 2012 06:56 PM
posho
Oct 30, 2009 09:42 AM
sevenfc
Apr 22, 2009 08:02 PM
torq2k
Oct 28, 2003 10:28 AM
airon
Jun 12, 2001 03:09 PM
