Power Steering bracket for 00' SI w/ H22
I have a 00' Civic Si that has an H22 in it. I've decided I wanted to add power steering but the stock mounts for the pump won't work. I know there's not a whole lot of room left but I've seen in done before. If anybody knows where I can buy some mounts or even fab some up I'd really appreciate it. Thanks.
What mounts are you using?
I had PS working on a 99 coupe. I used 94 brackets and pump. To make the PS line, you have to connect the metal line and the rubber hose to each other, you cant just clamp them together. The supply lines is hard to get working right, but you will figire it out.
DoNDoNJJJ
Jan 15, 2011 04:57 AM
Woodwardparts
Sep 26, 2005 06:53 PM
BoostedH23Accord
May 2, 2005 04:21 PM
rig9896
Aug 11, 2003 02:07 AM
