Power Steering bracket for 00' SI w/ H22
I have a 00' Civic Si that has an H22 in it. I've decided I wanted to add power steering but the stock mounts for the pump won't work. I know there's not a whole lot of room left but I've seen in done before. If anybody knows where I can buy some mounts or even fab some up I'd really appreciate it. Thanks.
Re: Power Steering bracket for 00' SI w/ H22 (tkimports)
I believe you need to use the stock 97+ lude pump and mate your upper metal line to the lude metal line.
Re: Power Steering bracket for 00' SI w/ H22 (fastwanabe)
I have the pump off of the 99' but the brackets mount the pump so close to the radiator support there's not enough room
What mounts are you using?
I had PS working on a 99 coupe. I used 94 brackets and pump. To make the PS line, you have to connect the metal line and the rubber hose to each other, you cant just clamp them together. The supply lines is hard to get working right, but you will figire it out.
Re: Power Steering bracket for 00' SI w/ H22 (turbogixxer)
I'm using the mounts that came on my motor. The clearance between the block and radiator support just doesn't seem like enough
DoNDoNJJJ
01-15-2011 04:57 AM
Woodwardparts
09-26-2005 06:53 PM
BoostedH23Accord
05-02-2005 04:21 PM
rig9896
08-11-2003 02:07 AM
