Tips for removing stubborn engine damper nut ??
Old Dec 18, 2004 | 02:32 PM
iperez's Avatar
Default Tips for removing stubborn engine damper nut ??
I'm trying to pull my engine damper to replace my tensioner but the frigging nut won't come out !! I tried an electric impact gun with no luck and I'd like to know if there's a good way to keep the crankshaft from turning while I pull some muscle with a breaker bar ?? PLEASE HELP !!
Old Dec 18, 2004 | 02:36 PM
Bbasso's Avatar
Default Re: Tips for removing stubborn engine damper nut ?? (iperez)
can you stick a rod of some sort in the fw opening and then try a breaker bar on the nut.
Is that even safe???
Old Dec 18, 2004 | 02:38 PM
Chris F's Avatar
Default Re: Tips for removing stubborn engine damper nut ?? (Bbasso)
Breaker bar and heavy hammer.
Old Dec 18, 2004 | 02:48 PM
iperez's Avatar
I'm not working on the tranny/clutch side and it would probably be more trouble than help to access the FW .. good idea though
As soon as I'm done with dinner I'm going to try the breaker/hammer combo again .. maybe I'll have better luck after a good meal
Any other suggestions ??
Old Dec 18, 2004 | 03:04 PM
Chris F's Avatar
Default Re: (iperez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">I'm not working on the tranny/clutch side and it would probably be more trouble than help to access the FW .. good idea though
Any other suggestions ??</TD></TR></TABLE>
Yeah, eat, that'll help.
What kind of electric impact gun? Do you know the ft-lb rating?
Old Dec 18, 2004 | 03:22 PM
iperez's Avatar
Craftsman A/C impact gun, rated at 240lbs torque. I actually went and bought this gun specifically to help me with the damper nut .. I'm upset about it so its going right back to the store seeing how I paid $179 for it and it didn't work.
Old Dec 18, 2004 | 03:32 PM
Chris F's Avatar
How persistent have you been with the gun? I would grab a beer, turn the radio on to the SF/WAS football game, and hit that thing for the next 20 minutes.
Then return it.
I assume you squirted WD40 before dinner? That might soak in and help. Good luck, I hate getting stuck on stupid **** like that.
One idea, I've used a jack (hydraulic or otherwise) to push a wrench when I didn't have the leverage or strength. You might wanna fiddle with that.
Caveat emptor, YMMV, IANAM, etc. etc. Don't break anything.
Old Dec 18, 2004 | 03:38 PM
uNF$@#!'s Avatar
Default Re: (Chris F)
liquid wrench = great.
breakerbar + hydro jack = even better
Old Dec 18, 2004 | 04:15 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to pull my engine damper to replace my tensioner but the frigging nut won't come out !! I tried an electric impact gun with no luck and I'd like to know if there's a good way to keep the crankshaft from turning while I pull some muscle with a breaker bar ?? PLEASE HELP !!</TD></TR></TABLE> :comfused: you are talking about the crank pulley bolt right?..there is a special tool for that. It looks like a thick bar with a chain that you can hook around, then push down on the bar, and wha-laa! its not going anywhere. Then, take a 2-3ft. braer bar, and a 19mm SNAP-ON socket to take it off. Dont be scared to lean really hard on it, if anything breaks its the socket. Which is replaceable for free. i snapped 3 sockets on a crank pulley that was torqued to 1200 ft. lbs. almost snapped the last one then i found out it was loosened. and it took 3 people to finally crack it loose.
good luck, i hope i helped.
Old Dec 18, 2004 | 04:20 PM
Chris F's Avatar
Default Re: Tips for removing stubborn engine damper nut ?? (Slow_Em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 &raquo;</TD></TR><TR><TD CLASS="quote"> :comfused: you are talking about the crank pulley bolt right? </TD></TR></TABLE>
Pulley, dampener, harmonic balancer, blah blah. Yeah, that's what he's talking about.
Edit, Wait a minute, that's what I was assuming... crankshaft pulley. Do you need to remove it to get to the tensioner?
Old Dec 18, 2004 | 05:12 PM
Dan GSR's Avatar
Default Re: Tips for removing stubborn engine damper nut ?? (Chris F)
yes
because you need to remove the timing belt cover, which is impossible to do without taking off the pulley
best thing to do is get a crank pulley holder
Old Dec 18, 2004 | 06:43 PM
Batoutahell's Avatar
This really could be THE most asked question on H-T.
If you don't have a good 450+ lb-ft impact gun, and you don't have the special tool, and you're not willing to remove the flywheel inspection plate so you can use a breaker bar, use a smoke wrench. Heat the bolt until it's red hot, let it cool, then try your impact gun. If that doesn't work, you might give a second thought to investing 5 minutes of your time to remove the fw inspection plate.
Old Dec 18, 2004 | 08:09 PM
KayOs's Avatar
Default Re: Tips for removing stubborn engine damper nut ?? (Batoutahell)
You need this (+ lots of liquid wrench + some heavy set cojones + someone to assist) to make your life a bit easier:
Old Dec 18, 2004 | 08:19 PM
baonest's Avatar
Default Re: Tips for removing stubborn engine damper nut ?? (KayOs)
my friend has that moroso tool (i think i still have it) if you need to use it (i think he lends it out to people) . but you gotta pay the price of the tool, shipping, and like $5 extra.
you will get your money back (except the $5 rental fee) when you return the tool.
if you are interested
Old Dec 18, 2004 | 08:47 PM
sander's Avatar
2.7(p/t)
Default Re: Tips for removing stubborn engine damper nut ?? (baonest)
http://www.autopart.com/TOOLS/...2.htm
I have this one, its a whole lot cheaper than the moroso tool, seems to work just fine for me, as 50 percent of hondas have stuck dampener bolts that wont even come off with a 3/4 impact wrench...
-s
Old Dec 18, 2004 | 09:25 PM
CoolJimWhy's Avatar
Default Re: Tips for removing stubborn engine damper nut ?? (sander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">_____________________________$$$____ $$_________________$$$__________ _$$$$$$$$$$$$$___$$__________$$$__$$$$____________ ___$$$$$$$$_______ $$$$$$$$$$$$$$$_$$$$________$$$$__$$$$___________$ $$_$$$$$$$$$$_____ $$_$$$____$$$$$_$$$$________$$$$__$$$$__________$$ $$__$$$$$$$$$$____ __$$$$_____$$$$_$$$$_______$$$$___$$$$_________$$$ $$__$$$$_$$$$$$___ _$$$$$___$$$$$__$$$$_______$$$$___$$$$$______$$$$$ $$__$$$$___$$$$$__ _$$$$__$$$$$____$$$$_______$$$$__$$$$$$_____$$$$$$ $___$$$$____$$$$__ _$$$$$$$$$______$$$$______$$$$___$$$$$$$__$$$$$$$$ $___$$$_____$$$$__ $$$$$$$_________$$$$______$$$$___$$$$$$$$$$$$__$$$ ___$$$$_____$$$$__ $$$$$$$_________$$$$_____$$$$____$$$_$$$$$$$___$$$ ___$$$$____$$$$___ $$$$$$$$$$$_____$$$$_____$$$$____$$$___$$$____$$$$ ___$$$___$$$$$$___ _$$$_$$$$$$$$___$$$$____$$$$$____$$$__________$$$_ ___$$$$$$$$$$_____ _$$$_____$$$$$___$$$$__$$$$$$____$$$__________$$$_ __$$$$$$$_________ _$$$____$$$$$$___$$$$$$$$$$$____$$$$__________$$$_ _$$$$_____________ _$$$$$$$$$$$$$____$$$$$$_$$$$___$$$__________$$$__ __$$$_____________ $$$$$$$$$$$________$$$___$$$$___$$$__________$$___ __$$$$____________ $$$$$$$___________________________________________ __$$$$____________ _$$_______________________________________________ __$$$_____________</TD></TR></TABLE>
Old Dec 19, 2004 | 05:48 AM
Bradstard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">Craftsman A/C impact gun, rated at 240lbs torque. I actually went and bought this gun specifically to help me with the damper nut .. I'm upset about it so its going right back to the store seeing how I paid $179 for it and it didn't work. </TD></TR></TABLE>
My 240lb Craftsman gun wouldn't get it off. I got the Earthquake gun from Harbor Freight for $79 and it does 625lbs. Worked like a champ.
Old Dec 19, 2004 | 11:31 AM
iperez's Avatar
Well.. after a tough Saturday night and early Sunday morning I've put everything back in the car and I'm driving to a friend's shop to use a proper air impact gun to get this nut off.. It sucks that I spent all this time and effort and I could not finish the task because of this nut !! Thanks for the comments, I really appreciate it guys !!
BTW, Fat Bastard, do you know Harbor Freight's web site url ??
Old Dec 19, 2004 | 04:23 PM
Bradstard's Avatar
BTW, Fat Bastard, do you know Harbor Freight's web site url ?? </TD></TR></TABLE>
Here's the link to the gun that I bought.
http://www.harborfreight.com/c...=2623
Old Dec 19, 2004 | 04:59 PM
Dan GSR's Avatar
Default Re: (Fat Bradstard)
sometimes a bolt just won't let go
I had an LS engine this week that wouldn't let go of a crank bolt even with a 800 ft/lb impact gun
Old Dec 19, 2004 | 05:48 PM
mikestypeRR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">How persistent have you been with the gun? I would grab a beer, turn the radio on to the SF/WAS football game, and hit that thing for the next 20 minutes.
.</TD></TR></TABLE>
hahahha hell yeah ....
Old Dec 19, 2004 | 10:40 PM
Slow_Em1's Avatar
Edit, Wait a minute, that's what I was assuming... crankshaft pulley. Do you need to remove it to get to the tensioner?</TD></TR></TABLE> yes, well at least to take the bottom cover off...there is a way of adjusting the tensioner without takeing that cover off...there is a little tiny tab you pull off on the side, its a rubber piece, round in shape. you shouldnt miss it. if its not there then stick a 14mm in there and loosen away.
Old Dec 20, 2004 | 04:27 AM
iperez's Avatar
Well, in my case, I need to replace the tensioner not just adjust it so I'm SOL ..
Ordering the impact gun right now, thanks Fat
JerseyJohnny
Jul 29, 2008 12:15 AM
Morasso
Feb 5, 2008 02:06 PM
redryder
18
Aug 27, 2005 12:14 PM
91_civicsi
20
Apr 12, 2005 06:05 PM
enigma94
11
Jun 14, 2004 09:10 PM
