How do you differentiate between JDM Integra motors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline07 »</TD></TR><TR><TD CLASS="quote">How do you know differentiate between a JDM GSR or a JDM TYPE R motor? Do both read "B18C" on the block?
on the R, the tranny would be stamped with LSD, the valve cover would be red, you can tell on the intake manifolds, obviously different. ummm, the header is different, more tubular and made of SS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech »</TD></TR><TR><TD CLASS="quote">I think that t type R is b18c5</TD></TR></TABLE>
umm, b18c5 is USDM i believe...
Both the JDM GSR and ITR have "B18C" stamped on the block.
Look at the head and you can tell if it is and ITR or GSR motor. GSR has a "P72" stamp and ITR has a "PR3" stamp.
Modified by Big Teggie at 11:32 AM 12/19/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">
Look at the head and you can tell if it is and ITR or GSR motor. GSR has a "P72" stamp and GSR has a "PR3" stamp. </TD></TR></TABLE>
THIS repley is the correct answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">Both the JDM GSR and ITR have "B18C" stamped on the block.
i think you meant the ITR has a PR3 head
Both are stamped B18C on the block. USUALLY the transmission will have LSD stamped on it for the ITR motor, however LSD was an option on some SIR-G's. The 98 was the first year that had the nice tubular header, 96 and 97's had a slightly different header (I believe it was a 4-2-1). I'm not going to touch the head stampings...I think the ITR is stamped P73...not totally sure though. You can also look at the intake manifold and tell if it's a SIR-G motor or ITR motor. Either way though, both motors are great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain »</TD></TR><TR><TD CLASS="quote">
I did, thanks man
</TD></TR></TABLE>I did, thanks man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze »</TD></TR><TR><TD CLASS="quote">where the hell do you people get "R" from? its just B18C not B18C R!!</TD></TR></TABLE>
just narrowing it down.....b18c can either be sir g or type R.....so people say b18cr
hope you get it
hope you get it
all jdm engine do not have numbers are the engine coad gsr's and itrs were both just b18c and all years b16's were just b16a
the visual differance between the gsr and itr motor is that the
itr has a red valve cover and the gsr has a black one
the itr has a single stage im and the gsr im points down which is a dual stage runner
the gsr head is stamped p72 and the itr is pr3
the 98+ itr has the 4-1 header with 2.5 colector
there is no other visual differance from the out side
if you really want to make sure just pull the valve cover and look for rings on the itr cams and paint on the valve springs
xschwinn24
28
Jul 1, 2006 03:32 PM
endlessdv
May 27, 2004 05:26 PM
