Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears
Old Dec 18, 2004 | 09:59 AM
allnapower's Avatar
Default Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears
Ordering Full Head Internals for my B20/B16vtec....found this package for 995 dollars. Any info on these? are these good internals? Any reccomendations?
Old Dec 18, 2004 | 10:00 AM
allnapower's Avatar
Default Re: Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears (fastcarsRlife)
Will my B20 block be able to handle higher RPMs?
Old Dec 18, 2004 | 11:18 AM
FairlightRacing's Avatar
Why are you even asking these questions? Of course the Omnipower valvetrain is good. There is a million threads saying its good. Same with the BC Spec III cams. Please do a search.
Old Dec 18, 2004 | 12:06 PM
allnapower's Avatar
Default Re: Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears (FairlightRacing)
Ive done many searches buddy, and I was just asking the main question of will my B20 block hold up well with high revs? no need to get mad boss.
Old Dec 18, 2004 | 12:57 PM
DIFFUT'S INC.'s Avatar
whats your compression going to be ?
Old Dec 18, 2004 | 01:24 PM
5thgenallmotor's Avatar
Default Re: Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears (DIFFUT'S INC.)
Is it a stock B20 with stock sleeves and rod bolts?
If so you are pushing your chances, although I had a boosted Stock B20 vtec with turbo last for 6 months at 9 pounds and 310 whp. Eventually the sleeve cracked though.
Old Dec 18, 2004 | 01:46 PM
Hotori Hanso's Avatar
Default Re: Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears (5thgenallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenallmotor &raquo;</TD></TR><TR><TD CLASS="quote">I had a boosted Stock B20 vtec with turbo</TD></TR></TABLE>
hahaha
and you will be just fine with omniman
Old Dec 18, 2004 | 03:20 PM
allnapower's Avatar
I've been hearing that OmniPower is a rip off of Buddy CLub....I've been told to just stick with Skunk2 Valvetrain...Do Any of you have omnipower?
Old Dec 18, 2004 | 03:59 PM
redED9Si's Avatar
b20'a are not really meant to handle high rpm, you probably really should rev it passed the stock CRV rev limit unless your bottom end really built (fully balanced, rod, pistons, etc)... I have also heard omniman valvetrain is get to rev on up to 9500 rpm, with a b16 and ****, but b20?? I dont' know
Old Dec 18, 2004 | 05:46 PM
allnapower's Avatar
Default Re: Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears (redED9Si)
Modified by fastcarsRlife at 5:03 AM 12/20/2004
Old Dec 18, 2004 | 05:54 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">Will my B20 block be able to handle higher RPMs?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">I was just asking the main question of will my B20 block hold up well with high revs?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redED9Si &raquo;</TD></TR><TR><TD CLASS="quote">b20'a are not really meant to handle high rpm, you probably really should rev it passed the stock CRV rev limit unless your bottom end really built</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">thats no help..but thanx anyway</TD></TR></TABLE>
Is there something wrong with you?
Old Dec 18, 2004 | 05:59 PM
Tbone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">I've been hearing that OmniPower is a rip off of Buddy CLub....I've been told to just stick with Skunk2 Valvetrain...Do Any of you have omnipower?</TD></TR></TABLE>
1.Thats 100% untrue.
2.You dont need to rev BC3's much more than 8k
3.Omnipower valvetrain is better than skunk's
Old Dec 18, 2004 | 07:47 PM
Combustion Contraption's Avatar
Im gonna be running full omnipower valvetrain including flat faced valves and buddy club cam gears very soon here... ill let everyone know how it goes.
Old Dec 19, 2004 | 08:59 AM
allnapower's Avatar
Default Re: Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears (Tbone)
thanks tbone bump
Old Dec 19, 2004 | 09:00 AM
allnapower's Avatar
Default Re: Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears (drdisco69)
hey drdisco get a life ....hahahahhahahahhaha loser
Old Dec 20, 2004 | 12:30 PM
EG617's Avatar
You dont need to rev high with the buddy club stage 3, so your block should be safe and since the lift on the cams isnt high and the cams peaks out a lil over 8k you dont really need to upgrade your valvetrain but its nice to have just in case
Old Dec 20, 2004 | 01:27 PM
631 Teggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">hey drdisco get a life ....hahahahhahahahhaha loser</TD></TR></TABLE>
No I think you should learn to read.... Your question was answered... Don't rev the stock block past b20 stock rev limit... Omnipower is good, BC is good. Your questions are answered.
Old Dec 20, 2004 | 10:19 PM
allnapower's Avatar
Default Re: Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears (631 Teggy)
your a loser to big dog but have fun with your lil life...bump to all those that helped thanks guys
Old Dec 20, 2004 | 11:15 PM
631 Teggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">your a loser to big dog</TD></TR></TABLE>
I'm a loser? Big dog? Read you dumb ****... All I'm saying is kid like you polute the boards with stupid questions when it's all been answered here 2,000,000,000 times... Fool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">but have fun with your lil life..</TD></TR></TABLE>
Who says that? ROFL - thanx I will have fun with my life...
Old Dec 21, 2004 | 04:46 AM
parks's Avatar
what about piston to valve clearance w/ stock B20 pistons? they're pretty flat(piston dome)....... last i heard anything more aggressive then GSR cams and your prob gunna see some contact
Old Dec 21, 2004 | 06:19 AM
Lip's Avatar
Lip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">your a loser to big dog but have fun with your lil life...bump to all those that helped thanks guys</TD></TR></TABLE>
relax or stay home without HT access
www.megameet.org
11
Oct 2, 2009 12:56 PM
rEnZ94tEgGy
Oct 5, 2008 06:18 AM
rare_db2
32
Jul 27, 2007 01:10 PM
Dallio
11
Jan 3, 2005 06:58 PM
2SLO
Apr 27, 2002 08:40 PM
