Injector, O rings, please look at picture
Where I put "O Ring?" do I need a rubber O ring like that GREEN one on top? Because I didn't use one and I installed it into my friends car. And the 2nd arrow, I used the stock nickel sized Washer.
What size injectors are those? When I installed my 310's, I kept the rubber rings that sit in the intake manifold.......the injectors rest on top of these......they do not plug in like the stock injectors..........you will probably have to add some metal washers to keep the fuel rail on right. There is no other o-ring for the end of the injector where you are pointing at. I can send you pictures of mine if you want......e-mail me.
They are 370 cc injectors, oh, so there is no O ring for that silver end? Hmm...strange....looks like its missing an O ring or something because of that groove
