do cams affect compression????? camshafts
Old Dec 18, 2004 | 02:15 AM
silversly's Avatar
BANNED
Default do cams affect compression????? camshafts
do camshafts affect compression????? i hear that smaller cams will give the motor more compression and big cams make the motor lose compression is that true??
Old Dec 18, 2004 | 05:16 AM
atcrx's Avatar
Default Re: do cams affect compression????? camshafts (Red Drag0n raWr)
yes. because of the overlap in the camshafts let out some of the fuel mixture while the intake and exhaust valves are open. A smaller camshaft has less overlap so it doesn't let out as much of the mixture. But this is all at low rpm. Thats why a big camsahft doesn't idle well.
Old Dec 18, 2004 | 05:20 AM
NJIN BUILDR's Avatar
If your talking cranking compression as in a compression gauge you are right.Bigger cams open the intake sooner and close the exhaust later,so there is less time to build cylinder pressure.This is why you want a higher compression ratio with a larger cam.With out doing this you loose low end torque from the loss of cylinder pressure.Big cams won't affect your compression ratio.
Glenn
Old Dec 18, 2004 | 06:59 AM
LudeyKrus's Avatar
Yes and no.
It will not drop the static compression (compression ratio) but it will drop the dynamic compression. As said, the duration will cause the air to flow out of the head when both valves are open, effectively losing compression while the motor is running. This is why you want to run a higher compression ratio with bigger cams.
Old Dec 18, 2004 | 08:02 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (LudeyKrus)
Intresting. I had a set of Civic Si cams in my 12.2:1 LSVTEC, and I was cranking over almost 300psi on a compression gauge..
integra123
May 10, 2006 01:05 PM
fsp31
11
Jun 7, 2005 05:18 AM
Modifiedinteg
Oct 29, 2003 06:46 AM
HX_Guy
Aug 22, 2001 02:00 PM
