car wont start up...
Old Dec 17, 2004 | 09:15 PM
scUba-stEve's Avatar
Default car wont start up...
i just rebuilt my motor and now my car wont start...the car would start to crank up(as if you were doing a compression test) but it will not turn over and start up...we pulled the spark plug out and tried to start it up but there was no spark coming out of the spark plug either...we think it could be a few things...the distributor, or the external coil(i have an msd setup)...what do you guys think?
Old Dec 18, 2004 | 10:00 AM
PrettyLude's Avatar
take a look at the ignitor, and the grounds
Old Dec 18, 2004 | 10:28 AM
Dragline's Avatar
Default Re: car wont start up... (b20vtecTURBOnos)
By pass the MSD I have had alot of problems with MSD if its not properly grounded or the coil is not properly grounded it will cause a headache of problems.To test your coil just unhook the white wire that goes to the dist on the MSD and with the key on pull the coil wire off the dist. cap and touch the white wire to ground and it should produce a spark every time you touch it to ground, if not your coil is bad.
dakotagurule
Jan 31, 2012 06:05 AM
GSR_EJ2
16
Sep 3, 2009 07:02 AM
brandonredsi
Mar 2, 2009 01:38 AM
jspek29
Feb 12, 2004 06:36 PM
phildeez
Mar 15, 2002 07:22 PM
