tach wire blue or green on 92 cx/ obd1 gsr??
I just put a obd1 gsr in a 92 cx hatch. I also put ina stewart warner digital tach with shift light(G.U.S.). I figured all the wiring out for the power and lights but i cant seem to find the tach wire, and yes i did use the search button. I tried tappin the green distributor wire and it turned the motor off. and i tried tapin into the wiring harness of the driver side under the hood where that blue wire is and still no luck . i even loked thro the ecu harness for a solid blue or gren wire no luck. If some 1 can tell me exactly where in the car the wire is not just what color it is i would appreciate it. also what it is near so its easy to find. This as been the hardest part of the swap for me lol
thanx
thanx
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
the rpm signal is the blue wire (coil negative) on the small connector on the distrib.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney »</TD></TR><TR><TD CLASS="quote">the rpm signal is the blue wire (coil negative) on the small connector on the distrib.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr2turbo007 »</TD></TR><TR><TD CLASS="quote"> and i want the solid blue right?</TD></TR></TABLE>
He could not have explained it better. It is right next to the Black/yellow and it is only a two wire connector.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr2turbo007 »</TD></TR><TR><TD CLASS="quote"> and i want the solid blue right?</TD></TR></TABLE>
thanx
thanx
This is where the blue wire is located
NeedACivic
May 7, 2003 01:57 PM
