Hasport A/C Bracket Information ...
Old Dec 17, 2004 | 05:16 PM
bossman032's Avatar
Default Hasport A/C Bracket Information ...
Ok
Type R Swap.
I wanna swap a motor I wanna keep the AC system whats needed?
Do I need to change Compressor etc??
If you don't know please don't say anything or try to confuse people
Wait for someone that has done this and they will explain
Old Dec 17, 2004 | 06:21 PM
88crxvtec's Avatar
Default Re: Hasport A/C Bracket Information ... (bossman032)
everything that was on your crx will work, I had one on my b16 and swapped everything over. OF course then I went turbo so....
Can't remember what belt but I think that was the crx one too.
Old Dec 17, 2004 | 06:56 PM
bossman032's Avatar
Default Re: Hasport A/C Bracket Information ... (88crxvtec)
did u have the hasport mount??
Old Dec 17, 2004 | 07:11 PM
88crxvtec's Avatar
yep I got one of the first, it was great!
Old Dec 17, 2004 | 07:13 PM
bossman032's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxvtec &raquo;</TD></TR><TR><TD CLASS="quote">yep I got one of the first, it was great!</TD></TR></TABLE>
I am talking about the AC mount plus I have a 89si hatch fyi
Old Dec 17, 2004 | 07:18 PM
HatchBox's Avatar
Skoobie no more...
call up hasport, direct answer
88crxvtec's Avatar
I have a 88 crx si and used hcp motor mounts with the hasport AC brackete
worked great
Old Dec 18, 2004 | 06:55 PM
NCchris's Avatar
I did a B18 swap into my CRX HF. Unbolt the AC compressor do not undo any lines. Zip tie the compressor to something handy. Remove engine and tranny, be carefull not to bend the hard AC lines. Install the Hasport bracket onto the engine being swapped in. Re install AC compressor after bolting in engine. Worked for me and I did not loose my freon. Also, I used Hasport mounts.
HTH
chris
endless_pain
14
Oct 8, 2022 10:48 AM
BOMBCRU
Apr 2, 2008 03:26 AM
ITR EG
Jun 8, 2006 01:21 PM
civic859
Feb 27, 2004 05:53 PM
SLeePeR012
Feb 21, 2004 05:59 PM
