Quick Integra Lowering spring question...
Old Dec 17, 2004 | 03:44 PM
01ITR#700's Avatar
Default Quick Integra Lowering spring question...
I located a set of Eibach Pro Kit's locally that are designed for 94+ Integra's. I'm curious if they will work on a '91 Integra? And is so, how much of a drop will I see and will the spring rates be ok?
Thanks a lot!
Mark
EDIT: Also, what about the struts, will KYB struts designed for 94+ Integra's physically fit onto a '91 Integra?
Modified by 01ITR#700 at 6:21 PM 12/17/2004
Old Dec 18, 2004 | 10:20 AM
01ITR#700's Avatar
Default Re: Quick Integra Lowering spring question... (01ITR#700)
ttt...anyone?
Thanks.
Mark
Old Dec 18, 2004 | 03:38 PM
strikeback03's Avatar
The springs will fit, spring rates and drop should be similar to advertized since the G3 isn't much heavier than the G2. For the struts you will need the front forks of an EG or DC, the DA dampers have a different diameter end, so the forks don't fit dampers designed for the EG/DC chassis. The rears will fit fine, so long as they weren't designed for a Type R.
Wrath of VTEC
Suspension & Brakes
May 1, 2014 11:42 AM
delsoldrew
Dec 10, 2009 08:02 PM
01ITR#700
Dec 18, 2004 10:34 AM
95cxhatch
Dec 21, 2003 07:02 AM
dsadas89das78934
Nov 1, 2003 10:00 AM
