Your opinion on running BC Stage IV cams @ 11.2:1 c ompression?
Old Dec 17, 2004 | 02:45 PM
JoeB18R's Avatar
Default Your opinion on running BC Stage IV cams @ 11.2:1 compression?
I’ve had members tell me that you really can run these cams at such a "low" compression. I’ve also had people (that I trust) tell me that while higher CR will get you more power, that by no means doesn’t mean that you can use and make decent power with such an aggressive cam at a lower compressions ratio (as long as we are talking 11:1 or higher anyway). I just want to get a general consensus here to see what you guys think. Since I’m looking to make ~200WHP, as well as wanting to make power all the way to 9K RPM, it seems like the Buddy Club Stage 4 cams are the way to go. I’m just concerned that at a little above 11:1, I won’t be able to make use out of such high lift and duration.
smithb299
Dec 2, 2008 07:52 AM
DC4R27
Apr 27, 2007 01:54 PM
PearlCrx
Mar 5, 2004 12:51 PM
roadawg
Dec 8, 2003 09:17 AM
