ek swap trouble code p1298 p0117
Old Dec 17, 2004 | 02:20 PM
HYBRIDHATCH92's Avatar
Default ek swap trouble code p1298 p0117
i just finshed this swap and i'm getting 2 codes p1298 ELD high voltage and p0117 ECT Sensor Circuit Low Input
car 99 hatch
swap 00 itr
the only things i'v changed was the altanator plug...the swap had a 0bd1 altanator so the plug was different....i cut the plug off the si harness and put a obd1 plug on it....i have read threw this post https://honda-tech.com/zerothread?id=448105
the #15 fues was not blown and i dont see any cut wires under the intake.....i'm really lost on this one and dont know where to go from here...if any of you guys could help it would be well appreciated
Thanks
Old Dec 17, 2004 | 03:27 PM
dantastic's Avatar
Default Re: ek swap trouble code p1298 p0117 (HYBRIDHATCH92)
you need an obd2 altenator most likely. not only is the plug different, but the innards might be different too. as for the ECT sensor, you might just need to clean the contacts for it
Old Dec 17, 2004 | 04:15 PM
Default Re: ek swap trouble code p1298 p0117 (dantastic)
does anybody know this for sure.....i really dont want to wast money on a altantor if thats not the problem....the one from my sohc will not bolt up right
Old Dec 18, 2004 | 08:00 AM
i'v also tried taking the plug out of the altanator and runing the car i still get the same code....anybody have any more idea's
xef_twinx
May 17, 2010 04:43 PM
grand champ
13
Jul 30, 2008 01:29 PM
2fast4udude
16
May 4, 2006 09:50 PM
