FS: Sport FWD race motor, Drive Shaft Shop DSS stage 6 axles
Old Dec 17, 2004 | 09:55 AM
Quik Chris's Avatar
Default FS: Sport FWD B18C5 race motor, Drive Shaft Shop DSS stage 5 axles
Race motor that I was going to use for SportFWD, but decided that with school coming up, I was never going to be able to finish it. Here's what it has on it, listed next to each part is what the part would retail for:
B18C5 block w/ golded eagle sleeves w/ 84mm bore GE block sleeveing, $1000
JE 9:1 forged pistons $550
Eagle rods $300
brand new ACL rod/main berings, thrust washers $110
Evolution sfi approved pulled (for running 11.50 or quicker) $200
port/polised B18C1 head dual valve springs, Skunk2 Titanium retainers mild port work, $300; springs & retainers $275
Golden eagle sandwich turbo feed kit $150
Golden eagle sheet metal polished intake manifold $750
ARP Head studs $115
2001 GS-R Transmission
ACT 6 puck clutch $450
GS-R motor would normally cost $3000 stock
The motor has never been started!! Everything adds up to $7350, Asking <FONT COLOR="red">$4500</FONT>
Driveshaft shop Stage 5 axles, good for up to 600whp. These axles were made before DSS did hub and intermediate shaft packages for levels 3-6. Brand new, they're $1600, asking <FONT COLOR="red">$900.</FONT>
Modified by Quik Chris at 11:55 AM 12/19/2004
Modified by Quik Chris at 3:52 PM 1/5/2005
Modified by Quik Chris at 6:45 PM 1/5/2005
Modified by Quik Chris at 8:42 PM 1/5/2005
Old Dec 19, 2004 | 10:00 AM
Quik Chris's Avatar
Default Re: FS: Sport FWD B18C5 race motor, Drive Shaft Shop DSS stage 6 axles (Quik Chris)
bump
Old Dec 31, 2004 | 07:13 PM
Code Blue's Avatar
i want those axles
Old Jan 2, 2005 | 09:35 AM
Quik Chris's Avatar
Default Re: FS: Sport FWD B18C5 race motor, Drive Shaft Shop DSS stage 6 axles (Code Blue)
bump-- selling all this to do a less expensive K20A2 in my hatchback. Got in this far, and then crunched some numbers-- found out I still need $800 for a turbo, $1500 for a clutch, $1600 for ECU, $500 for intercooler $500 for aluminum bends, $200 worth of Argon for TIG welding it all, $1350 for a manifold, etc etc-- just can't do it. I start school again on Jan 10, and I'm not coming up with the money by then
Old Jan 2, 2005 | 10:07 PM
jdub db8's Avatar
one question. whay is the block and water tube missing the fittings for the factory oil cooler? Is that because of the sleeves?
Old Jan 2, 2005 | 10:53 PM
xtremeness101's Avatar
Default Re: FS: Sport FWD B18C5 race motor, Drive Shaft Shop DSS stage 6 axles (Jester_Si)
would you sell just the block without the head... please let me know asap..... how much? thanks... need to buy asap.
Old Jan 3, 2005 | 02:17 AM
Quik Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester_Si &raquo;</TD></TR><TR><TD CLASS="quote">one question. whay is the block and water tube missing the fittings for the factory oil cooler? Is that because of the sleeves?</TD></TR></TABLE>
No-- the water pipe, I believe is off a type R, but the oil cooler is off of GS-R-- I was going to just leave the oil cooler disconnected on the coolant side. Kept the Type R water pipe becuase I would have just welded the other ports up anyway.
Old Jan 4, 2005 | 08:22 AM
jdub db8's Avatar
Bump. Thanks, i am going to shoot you a call today.
Old Jan 4, 2005 | 07:12 PM
Quik Chris's Avatar
Ok (bump). I'm ready for the call.
Old Jan 4, 2005 | 08:39 PM
Aggressive Racing's Avatar
im'ed you about the axles
Old Jan 5, 2005 | 01:55 PM
Quik Chris's Avatar
Default Re: FS: Sport FWD B18C5 race motor, Drive Shaft Shop DSS stage 6 axles (jerseykid609)
Edited info on axles and dropped price to $900.
Old Jan 5, 2005 | 04:43 PM
Quik Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">arent thoes stage 5's stage 6's require a special hub thats only 5 lug they look to be stake 5's from that angle.. could u verify ?</TD></TR></TABLE>
Word, thanks a lot-- they are stage fives after examining the box.
Old Jan 5, 2005 | 06:00 PM
DefiantGSR's Avatar
Default Re: FS: Sport FWD B18C5 race motor, Drive Shaft Shop DSS stage 5 axles (Quik Chris)
eagle rods do not retail for 450. they're 300 shipped.
ARP headstuds aren't 250. they're 115 shipped.
Old Jan 5, 2005 | 06:41 PM
Quik Chris's Avatar
Default Re: FS: Sport FWD B18C5 race motor, Drive Shaft Shop DSS stage 5 axles (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">eagle rods do not retail for 450. they're 300 shipped.
ARP headstuds aren't 250. they're 115 shipped. </TD></TR></TABLE>
Sorry, was trying to remember all of them off the top of my head. Regardless, it's a good deal. Thanks for pointing that out.
Old Jan 10, 2005 | 08:08 AM
Quik Chris's Avatar
bummp
Old Jan 17, 2005 | 10:40 AM
05 S2K Stoner's Avatar
PMED
tmar253
Aug 7, 2013 08:13 AM
pimpinainteasy
Sep 27, 2009 12:43 PM
Frankie92481
Sep 30, 2006 07:41 AM
b19coupe
17
Aug 4, 2005 04:32 AM
