ls/vtec girdle - do I need it??
Old Dec 17, 2004 | 07:38 AM
awdriscol4's Avatar
Default ls/vtec girdle - do I need it??
What are everyone's opinions on girdles for ls/vtec builds? Im looking at the Golden Eagle kit, which includes the girdle, gsr main bolts, windage tray and oil pickup, and its around $380. My motor is a NA ls/vtec, with ctr pistons, etc...basically a high compression NA motor.
Is the girdle worth the cost? Also, the info says "All girdles MAY require block align boring AFTER install!" What is block align boring?
Thanks
Alfred
Old Dec 17, 2004 | 07:47 AM
mmuller's Avatar
Mad Scientist
Default Re: ls/vtec girdle - do I need it?? (awdriscol4)
on my opinion is not necessary, but..
they say you might have to line bore since torquing the girdle down might distort(egg shape) the mains.
also make sure the girlde is dowelled.
Also if your going to do it i would use a 5 main girdle instead of 3
Old Dec 17, 2004 | 08:04 AM
earl's Avatar
unless you are making over 600whp, you don't need one. Lisa Kubo, in her old ls/vtec days, never had to use a girdle.
Old Dec 17, 2004 | 03:11 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: ls/vtec girdle - do I need it?? (earl)
I don't have one...
Old Dec 17, 2004 | 04:14 PM
DIFFUT'S INC.'s Avatar
Default Re: ls/vtec girdle - do I need it?? (LSVTEC 91 Civic)
i use a Z10 girdle in my track car. i rather be safe then sorry at the end. GSR and Type R Stock come with them and they not even close to 200 whp Stock .
Old Dec 17, 2004 | 05:42 PM
93lsd's Avatar
Default Re: ls/vtec girdle - do I need it?? (DIFFUT'S INC.)
yea i think it would be the safest 150.00 dollors spent. and what will you be reving it too
Old Dec 18, 2004 | 08:28 AM
awdriscol4's Avatar
Default Re: ls/vtec girdle - do I need it?? (93lsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lsd &raquo;</TD></TR><TR><TD CLASS="quote">yea i think it would be the safest 150.00 dollors spent. and what will you be reving it too</TD></TR></TABLE>
I cant imagine going any higher that 9k.
Also, it's alot more than $150, because you also need a gsr oil pan and oil pickup, gsr main bolts, and if you going to do it right, dowls to correctly line up the girdle, Im guhessing around $400 total. But it sounds like its a good investment....
Old Dec 18, 2004 | 10:29 AM
DC-4-Drew's Avatar
I am having a stock GSR girdle and the LS caps machined to fit. The LS block and crank is not designed to rev very high. Do it.
97_coupe
14
Feb 11, 2008 05:37 PM
awdriscol4
Dec 16, 2004 11:41 PM
ponykillergsr
Feb 22, 2003 01:22 AM
mskibbz-T
Nov 1, 2002 12:39 PM
LS-T
Oct 30, 2001 03:57 PM
