putting in new valves
Old Dec 17, 2004 | 06:53 AM
turbo sol's Avatar
Default putting in new valves
I will be replacing my vlaves soon. I was going to take the valves and get a 3 angle valve job done for 10/valve
I am able to buy new valves at ~11/valve normal 18/valve performance
I already have new unused valve seals. I am competent in my ability to remove and reistall valves. is there anythign i am missing? or anything i should be aware of?
for just a little more money I can get new valaves and that sounds like a good thing.
Old Dec 17, 2004 | 07:26 AM
tgreaves's Avatar
Default Re: putting in new valves (turbo sol)
I would get the new valves.. Your going to need to take the head and have the 3 angle job done on it.. I would also upgrade the springs and retainers while your in there..
Old Dec 17, 2004 | 10:15 AM
turbo sol's Avatar
Default Re: putting in new valves (tgreaves)
i was told the valves are ready to be dropped in and do not need to be cuut (3 angle job)
I don't plan on reving the **** out the car so stock valve train will be fine. I have a bent valve and need the engine running again.
would anything be wrong with just replacing the seals and putting in new valves?
Old Dec 17, 2004 | 10:16 AM
tgreaves's Avatar
You just need to lap the new valves into the head..
Old Dec 17, 2004 | 11:11 AM
civicsitek GanGsTa's Avatar
just replace with stock valves send all of them in with the head and have the valves ground.
Old Dec 17, 2004 | 12:21 PM
turbo sol's Avatar
Default Re: putting in new valves (civicsitek GanGsTa)
for the price of stock valves getting a valve job i can get new valves.
I think the lapping idea is a good one. any more info on lapping.
that is just to give the valves a good seat against the head correct?
Old Dec 17, 2004 | 12:23 PM
tgreaves's Avatar
Correct.. Just get some lapping compound and a lapping tool and go at it.. When your ready IM me and ill give you directions of how to do it.. If your replacing the valve seals then its easiest to lap them when the valve seals are off the head..
Old Dec 17, 2004 | 01:28 PM
turbo sol's Avatar
thanks. I will DEF im you when I actually get going on this.
thanks for the help guys.
kornerk12
11
Jul 3, 2009 03:55 AM
VTECcnIT
Nov 9, 2005 05:43 AM
D50boy
Jun 2, 2005 02:39 PM
JeffNA
May 20, 2002 06:59 AM
