HEATER WILL NOT BLOW HOT AIR
Old Dec 17, 2004 | 06:38 AM
CHRIS_COLMENERO's Avatar
Default HEATER WILL NOT BLOW HOT AIR
I HAVE BEEN TOLD MANY DIFFERENT THINGS THAT IT COULD BE MY HEATER CORE, AND SOMETHING ABOUT A BYPASS VALVE. I HAVE NO IDEA WHAT IT COULD BE. IT IS A 99 CIVIC EX COUPE. MY AC WORKS BUT THERE IS ABSOLUTELY NO HEAT AND ITS FREEZING. PLEASE HELP.
Old Dec 17, 2004 | 06:39 AM
smithenhiven's Avatar
11:11
Default Re: HEATER WILL NOT BLOW HOT AIR (CHRIS_COLMENERO)
First, turn your capslock off.
Did you check your blower motor?
Old Dec 17, 2004 | 06:43 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: HEATER WILL NOT BLOW HOT AIR (smithenhiven)
his a/c works so his blower motor is fine.
feel the lines going to and from the heater core. If one is hot and the other is cold then your heater core is clogged and/or bad and you will need to replace it.
now go away and freeze muhahahhahahhaha
jjcard41
Honda Civic (2006 - 2015)
Dec 12, 2014 07:00 PM
Alucard1261
Dec 4, 2009 12:48 PM
allanonjj
Jun 17, 2009 01:46 PM
cascaritas
17
Sep 22, 2004 06:50 PM
BoostedAcura
Sep 10, 2002 07:20 PM
