DC5 Shifter question...
Why did Honda utilize a cable shifter assembly in k-series transmissions, rather than using a shift-linkage, like in the b-series? What is the key variable examined when it comes to deciding on which style shifter to use?
I would say it has something to do with the subframe. If you'ce ever examine the undercarragie of the rsx, you will see that there are a bunch of **** in the way. Having the rods like traditional b-series would be a pain to make, remove, or repair.
I want to bump this from the dead, to see if anyone might have an 'official' technical reason for Honda using the cable shifter -- just out of curiosity.
I have driven my EP for around 2 years now and at first the cable shifter wasn't that big of a deal; but after trying my hand at a couple autox events the cable shifter really feels like a step back for the good folks at Honda. It makes you feel disconnected from the engine, makes shifting feel crunchy and it doesn't feel as fluid/precise as linkages.
The only answer looks to be for 'noise reduction' purposes; but it seems like such extreme measures of noise reduction would be somewhat counterproductive for the EP3 and DC5, which should be considered more sport sub-compact than luxury.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8point6 »</TD></TR><TR><TD CLASS="quote">Why would the header location have anything to do with deciding on which type of shifter to use?</TD></TR></TABLE>
hmm...well.. engine is tilted bit back (looks that way anyways) and also note tranny is switched to other side compared to B series so like PrettyLude said its got different design and so on
the main concern imo is the design of tranny and cost. the shifting levers in the tranny shouldbe in line w/ levers and rod coming out of the car if u want levers and make cost less expensive. cables let the tranny designer more freedom and cost LESS to produce and install in assembly line.
a positive shifting mechanism is always better, better feel, faster shifts and more robust design.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stewyman »</TD></TR><TR><TD CLASS="quote">New Engine, New Tranny they just did what they wanted too
Hmmm...
Hmmm...
honey mead
Aug 13, 2006 03:56 PM
