50 lbs/min (640cfm)...------------------- which injectors?
Old Dec 17, 2004 | 02:06 AM
untitled's Avatar
Default 50 lbs/min (640cfm)...------------------- which injectors?
looking for 300-400whp range...
I have 440's. They should be maxed out or close to maxed on a setup like this. t3/t04e 57trim .48ar turbine blows 50 lbs/min 640cfm I want a set of injectors that will be at about 70% duty cycle with turbo at maximum efficiency. Also, does anyone have any links to a good injector sizing calc?
Old Dec 17, 2004 | 05:39 AM
non-VTEC's Avatar
Default Re: 50 lbs/min (640cfm)...------------------- which injectors? (untitled)
650 or higher??
Old Dec 17, 2004 | 05:43 AM
mrbsponge's Avatar
just us 880s and not have to worry
Old Dec 17, 2004 | 08:25 AM
b18bturbo's Avatar
Default Re: (mrbsponge)
anything above 680 cc will give you want you need in that power range. if you plan going higher in the future do as one user said get the 880cc if you can control it with your ecu
tinymotor22
Apr 16, 2008 06:48 PM
feriotypeR
Feb 22, 2008 02:31 PM
DailyBlown
Aug 3, 2003 08:00 AM
egg
Feb 15, 2003 11:29 AM
