braided clutch line diameter?
Old Dec 17, 2004 | 01:50 AM
an2ny888's Avatar
Default braided clutch line diameter?
i'm going to make my own braided clutch line to see if it will help out with my stiff *** aftermarket clutch. what size fittings and what diameter braided line do i need? tnx
Old Dec 17, 2004 | 02:14 AM
davidnyc's Avatar
Default Re: braided clutch line diameter? (an2ny888)
I am curious... help out in what way? What are you trying to achieve?
Old Dec 17, 2004 | 02:40 AM
an2ny888's Avatar
Default Re: braided clutch line diameter? (davidnyc)
i've heard it gives better pedal feel and that it reduces pedal effort a little bit
Old Dec 17, 2004 | 06:32 AM
IN VTEC's Avatar
-3AN.
Make sure you use the teflon inner-lined braided line with steel fittings. The non-teflon lined hose will be less up to taking the pressure. The application might fall under the specifications for maximum pressure rating for non-teflon hose, but you should always used teflon-lined inner hose for high pressure apps.
Or, you could just buy a pre-fabricated FLP line from heeltoeauto for $20 to $30 and call it a day instead of looking all day for the metric adapter fittings.
Old Dec 17, 2004 | 06:33 AM
an2ny888's Avatar
Default Re: braided clutch line diameter? (IN VTEC)
tnx for the info
Old Dec 17, 2004 | 07:05 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">i've heard </TD></TR></TABLE>
Hah...
Old Dec 17, 2004 | 11:19 AM
Bbasso's Avatar
Some things that relate to your question.
https://honda-tech.com/zerothread?id=871805
https://honda-tech.com/zerothread?id=968781
https://honda-tech.com/zerothread?id=796422
https://honda-tech.com/zerothread?id=420851
https://honda-tech.com/zerothread?id=254902
https://honda-tech.com/zerothread?id=252466
https://honda-tech.com/zerothread?id=181554
https://honda-tech.com/zerothread?id=48152
B18c5__Owns
Mar 25, 2009 12:48 PM
defnu
Sep 15, 2008 11:49 AM
t3to4e
Jun 29, 2006 03:14 AM
jackhunt321
Nov 3, 2005 02:33 PM
youngkow
Jan 17, 2003 01:00 PM
