weird brake pad wearing
Old Dec 16, 2004 | 09:36 PM
Joon Joon's Avatar
Default weird brake pad wearing
hey i put some brake pads on my 94 ex last summer and when i changed them the last time the drivers side pad wore out weird.. the bottom work out before the top and the passanger side ones were koo... now these pads are wearing out the same and i gotta change these out.. when i change these i'mma put some brembo blanks and some axxis ultimate pads.. does anyone know why the drivers side would wear like that??
Old Dec 16, 2004 | 09:44 PM
t0p_sh0tta's Avatar
Default Re: weird brake pad wearing (vtecenjun)
Are you missing any of the pad hardware? Are both retaining clips in good shape?
Modified by t0p_sh0tta at 2:53 AM 12/17/2004
Old Dec 16, 2004 | 09:46 PM
DAguyLS's Avatar
thats what i was thinking, the retaining clips
possibly the brakes aren't setting in flush with the rotor because the clips aren't "retaining" properly
makes sense anyways
Old Dec 16, 2004 | 09:48 PM
Joon Joon's Avatar
Default Re: (slamdLScivic)
yup they were in good condition when i last put the other ones on.. nothing missing
Old Dec 17, 2004 | 04:24 AM
ironlung78's Avatar
your caliper could be slightly hanging up just enough to cause abnormal pad wear
Old Dec 17, 2004 | 05:45 AM
Joon Joon's Avatar
Default Re: weird brake pad wearing (sidesi)
hey sidesi.. wat do you mean by hanging up?? i'm not really sure wat you mean by that
Old Dec 17, 2004 | 06:44 AM
00Red_SiR's Avatar
All Motor Mentor
It means that the caliper slider bolts may need to be cleaned and re-lubed so the caliper will slide properly and evenly to engage the brakes. If this isn't done everytime the brakes are changed, they can "hang up" and not engage evenly and cause uneven pad wear or even drag causing the car to pull to one side because the caliper doesn't release properly.
Old Dec 17, 2004 | 06:50 AM
Joon Joon's Avatar
Default Re: weird brake pad wearing (00Red_SiR)
koo thanks guys.. i ordered my blanks last night and i'll be ordering my ultimates from my friend.. so when everything comes in i'll be lubing those things up real well..
Old Dec 17, 2004 | 06:59 AM
B18C5-EH2's Avatar
Former Moderator
Loved
If cleaning the pins doesn't work then it's time for a new caliper.
Old Dec 17, 2004 | 08:25 AM
skunk2eg's Avatar
Default Re: weird brake pad wearing (B18C5-EH2)
have you checked all the lines from the master cylander, it may have a pinch or a slight tear, that could be a cause
Old Dec 17, 2004 | 08:55 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">It means that the caliper slider bolts may need to be cleaned and re-lubed so the caliper will slide properly and evenly to engage the brakes.</TD></TR></TABLE>
bingo
Old Dec 17, 2004 | 09:41 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: weird brake pad wearing (rodney)
Here is a writeup I did for a friend on cleaning & preping used rear calipers for install. Fronts are almost exactly the same (w/o parking brake), so you shouldn't have a problem following the pics. Hope this helps you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">The caliper guide pins are #22 & #38 in this pic. Only work on one side at a time, so they don't get mixed up. First unbolt the caliper completely & hang it in the wheel well. Then unbolt the caliper mounting bracket (it doesn't have a number, but it's next to #21) and take it to your work bench. Now pick one of the pins and pull it out (only remove one because they are different and can get mixed up). The rubber boot (#21) will just pop off, and the pin should come right out. Next, remove the boot & clean the inside out. Next, take a few Q-tips, and clean all the old grease & gunk out of the hole the pin came out of. Then clean the pin & apply some fresh disc brake grease. Reinstall the boot on the bracket, and squirt a little grease into the boot & a little down the hole. Now reinstall the pin, and make sure you can push it all the way in. The grease will create an air pocket at the botom, so you may have to work the pin back & forth to get it in all the way. Next, with the pad retainers (#28) installed on the bracket, test fit your brake pads (only use new pad retainers). If they can't move around in the bracket without effort, grind the ends of the pad ears down. Use a file or grinder until they move smoothly. Next clean up the ground area w/ some sand paper & wash them off. Now put disc brake grease onto the pad retainers & the ears of the brake pads. Now lube the pad springs (#15) where they touch the pads (only use new pad springs). Then just reinstall everything w/ a little bit of red brake goo on the piston/caliper contact surfaces, and repeat this whole thing on the other side.
Once your done, slowly drive the car & make sure everything works. Next you must "bed in" the pads (this may get rid of the noise problem by itself). Drive the car and make 4 or 5 medium pressure slow downs (don't stop the car) from 50mph to 10mph. This will start to heat up the brakes. Now drive around for 10 to 15 minutes wile using as little braking as possible (this is the pain in the *** part). Now make 4 or 5 heavy pressure stops from 55-10mph (be prepared for brake fade). Once this is done, drive around for another 10-15 minutes to let the brakes cool down. Now park the car for a few hours w/o using the parking brake. This will let the pads temper. At this point there shouldn't be any noise or problems. If noise still persists, I would suggest returning your pads because they may be defective.
Old Dec 17, 2004 | 06:37 PM
Joon Joon's Avatar
thanks for all the replies.. i think i'll do the write up thing.. its pretty simple since i'm going to change the rotors too so the caliper bracket will be off.. thanks again.. and happy holidays..
Tenzo
Suspension & Brakes
May 13, 2012 11:03 AM
MrDomino
May 16, 2008 08:42 AM
Philip
Oct 31, 2003 09:07 PM
Chris y0!
10
Jan 8, 2003 09:14 PM
OEMaccord
13
Sep 20, 2002 11:08 AM
