404 cams in non-vtec what numbers should i use for valve clearance?
Old Dec 16, 2004 | 08:43 PM
egsi32's Avatar
Default 404 cams in non-vtec what numbers should i use for valve clearance?
i have stock b20z bottom end. and crower valvetrain with 3 angle cut valves. i am about to install the 404 cams and what to know what to set the valve lash at? i know what the stock ones are suppose to be set at. should i give them more room or less room with the 404 cams? please explain? thank you for any help.
Old Dec 16, 2004 | 08:59 PM
evilempire's Avatar
Default Re: 404 cams in non-vtec what numbers should i use for valve clearance? (egsi32)
Part Number/Work Order Number 62404
Engine Application ACURA 1.8 LS/RS
Grind Number 243-237 D0HC
ADVERTISED CAMSHAFT SPECIFICATIONS:
INTAKE: Duration: 243º Lift: 0.445 Clearence Hot: 0.006
EXHAUST: Duration: 241º Lift: 0.434 Clearence Hot: 0.008
That's from crowers site. It shouldn't be hot though. I'd just wait till you get the cams and it will come with a spec sheet.
Old Dec 16, 2004 | 09:14 PM
egsi32's Avatar
Default Re: 404 cams in non-vtec what numbers should i use for valve clearance? (evilempire)
if those numbers are for hot then what would be safe when cold? does increasing the space make the valve tighter or looser? i know if they are too loose they will tick at idle? so if i tighten them up i need to raise increase the space or decrease it?
Old Dec 16, 2004 | 09:20 PM
StyleTEG's Avatar
just do it hot, let the engine warm up for 20min and then do the valve lash.
Setting the clearance smaller makes the it tighter.
Old Dec 16, 2004 | 09:34 PM
egsi32's Avatar
Default Re: 404 cams in non-vtec what numbers should i use for valve clearance? (StyleTEG)
thanks. will i have to set it tighter if i set it cold.
Old Dec 17, 2004 | 07:20 AM
egsi32's Avatar
i am going to go with the stock specs to set the valve clearance. and im going to do it when its running cold. should i set the valve lash tighter than stock spec or looser? why? how much tighter or looser should i set the valve lash? how much too tight or too loose can i run the valve lash before i have to worry? does anyone have 404 cams in there setup? i have stock bottom b20z and need to know how much i can tighten the valve lash. can anyone help me please?
Old Dec 17, 2004 | 07:24 AM
StyleTEG's Avatar
I really don't understand why you want to blatently set the valve lash wrong?
I have 404s, set it to what crower recommends and set it when the engine is hot.
If that is too complicated you really shouldn't be doing a cam install in the first place.
Old Dec 17, 2004 | 07:26 AM
egsi32's Avatar
everyone tells me to run it dead cold. i have read many post where all people have it set when its cold. the helms manual says to do it when its cold too? but i guess you should know because your the person everyone says has good numbers with those cams. so i will just go with what you said then. thanks
Old Dec 17, 2004 | 08:20 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">I really don't understand why you want to blatently set the valve lash wrong?
If that is too complicated you really shouldn't be doing a cam install in the first place.</TD></TR></TABLE>
I thought valve adjustments were set cold b/c once the engine warms up the metal expands. Correct me if I am wrong, thanx.
Anyway Crower recommends that you set the valve lash to .006 Intake, and .008 Exhaust. I wouldn't vary too much if at all from what crower recommends.
Old Dec 17, 2004 | 08:31 AM
dohcter g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evilempire &raquo;</TD></TR><TR><TD CLASS="quote">Clearence Hot: 0.006
Clearence Hot: 0.008 </TD></TR></TABLE>
This is cold
Old Dec 17, 2004 | 08:34 AM
StyleTEG's Avatar
Default Re: 404 cams in non-vtec what numbers should i use for valve clearance? (hybrid_vtec)
Yeah, some manufactures and OEM specify that you should set the valve lash cold for that reason.
However if the motor is warmed up, the internals should expand to relatively the same point (for all practical purposes) so you can also set the lash hot as well. I don't know why crower has HOT clearances instead of cold specificly, but I would venture that it probably has to do with the accuracy of having the clearances dead on when the engine is running vs when the engine isn't.
The cams also might be made with different grades of material than OEM, and may expand/contract differently.
The crower card that came with my cams specificed hot clearances.
Old Dec 17, 2004 | 08:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, some manufactures and OEM specify that you should set the valve lash cold for that reason.
The crower card that came with my cams specificed hot clearances.</TD></TR></TABLE>
hmm... mine said cold, but the site says hot. I dunno! I might just email Brian and ask him!
Old Dec 17, 2004 | 02:42 PM
Darkane's Avatar
yeah my card says cold also.. hmm interesting to see what Brian says when u email him.
Old Dec 18, 2004 | 08:28 PM
whatVTEC's Avatar
Default Re: 404 cams in non-vtec what numbers should i use for valve clearance? (Darkane)
I've always done mine cold
Old Dec 19, 2004 | 12:39 AM
Eviloliv3's Avatar
Default Re: 404 cams in non-vtec what numbers should i use for valve clearance? (whatVTEC)
i would think it would be more accurate if you did it cold.
stock specs are .004 Intake and .007 Exhaust when cold
if you were adjusting them when hot, youll be accurate on the first one, but each one the motor is getting colder and colder, so the metal will slowly shrink, so youll have your 1st and 3rd cylinder be right on, but by the time you get to 4th and 2nd, it wont be so accurate
Old Dec 19, 2004 | 08:21 AM
non-VTEC's Avatar
Default Re: 404 cams in non-vtec what numbers should i use for valve clearance? (Eviloliv3)
i always set my valve lash cold. and i found .005in .006ex COLD works well and sounds the best with my crower cams.
you can run it how crower recommends but its to loud for my tastes.
Old Dec 19, 2004 | 10:56 AM
Default Re: 404 cams in non-vtec what numbers should i use for valve clearance? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i always set my valve lash cold. and i found .005in .006ex COLD works well and sounds the best with my crower cams.
you can run it how crower recommends but its to loud for my tastes.</TD></TR></TABLE>
Is this on your 404's?
Old Dec 19, 2004 | 02:43 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Is this on your 404's?</TD></TR></TABLE>
403's........but they have the same vlave lash specs.
Old Dec 19, 2004 | 05:52 PM
403's........but they have the same vlave lash specs.</TD></TR></TABLE>
I know I had 403's before my 404's! That just seems tight clearances to me for the exhaust side!
Old Dec 19, 2004 | 06:38 PM
non-VTEC's Avatar
I know I had 403's before my 404's! That just seems tight clearances to me for the exhaust side!</TD></TR></TABLE>
nah........ .002 tighter is still within factory spec and still works well........ran those for 4-5 years like that..........
Old Dec 20, 2004 | 03:34 AM
nah........ .002 tighter is still within factory spec and still works well........ran those for 4-5 years like that.......... </TD></TR></TABLE>
I might try that then, b/c my valvetrain is too noisy now
jceltalentoso
Jan 27, 2014 08:54 PM
BIGef
Oct 14, 2013 01:44 PM
exownzu
Sep 30, 2006 08:58 AM
mugenracer
Mar 13, 2005 09:29 PM
