CHRISTMAS SALE: SPARK RACING .:SANTA CLAUSE LIST:. * SUPER SALE *
ULTIMATE CHRISTMAS SALE: SPARK RACING .:SANTA CLAUS LIST:. * SUPER SALE * 56K NO WAY * IF YOU DONT TAKE A LOOK YOUR ON SANTAS BAD LIST
<FONT SIZE="10">EVERYTHING ON SALE</FONT>
<FONT SIZE="10">MUCH MORE NOT LISTED</FONT>
ALL INSTOCK CHRISTMAS SPECIAL BEST PRICES:
ALL SPARK RACING/ RS RACING BLOCKS 10% OFF
Custom Race Blocks
H22A Add $500
D-Series Same Price
GSR Series Add $500
B18A/B Blocks
*Note Knife edge crank add $300
Naturally Aspirated
Stage 1 Street Version N/A
Price: $1295.95 price includes core
B18A/B Block 1.8 liters
ITR Pistons and rings oversized
Rods Stock
Micro polished crank
Bore and Honed
New main and rod bearings
New oil Pump
New water pump
Assembly
Stage 2 Street Version N/A
Price: $1495.95 price includes core
81 mm 11.5:1 Arias Pistons
Rods Stock
Bore and Honed
New oil Pump
New water pump
Assembly
Stage 3 Street Version N/A
Price: $2495.95 price includes core
B18A/B Block 2.0 liters
85 mm 11.5:1 Arias Pistons
Rods Stock
Darton Sleeves
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Stage 4 Street Version N/A
Price: $2795.95 price includes core
Eagle Rods
Darton Sleeves
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Stage 5 Drag Version N/A
Price: $2995.95 price includes core
85 mm MAX DOME Arias Pistons
Eagle Rods
Darton Sleeves
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Stage 6 Drag Version N/A
Price: $3995.95 price includes core
B18A/B Block 2.2 liters
86 mm MAX DOME Arias Pistons
Custom Rods
95mm Stroked Micro polished crank
Darton Sleeves
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Stage 7 Drag Version N/A
Price: $4995.95 price includes core
B18A Block 2.3 liters
½ Deck Extension
86 mm MAX DOME Arias Pistons w/ gas ports
Custom Rods
100mm Stroked Micro polished crank
Darton Sleeves
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Stage 1 Street Version Turbo
81mm 9:1 Arias Pistons
Rods Stock
Bore and Honed
New oil Pump
New water pump
Assembly
Stage 2 Street Version Turbo
Price: $1949.95 price includes core
Eagle Rods
Bore and Honed
New oil Pump
New water pump
Assembly
Stage 3 Street Version Turbo
B18A/B Block 1.9 liters
83mm 9:1 Arias Pistons
Eagle Rods
Darton Sleeves
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Stage 4 Street Version Turbo
Price: $3095.95 price includes core
Crower Rods
Darton Sleeves
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Stage 5 Drag Version Turbo
83mm 10:1 Arias Pistons
Crower Rods
Darton Sleeves
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Stage 6 Drag Version Turbo
Price: $3895.95 price includes core
Crower Rods
Darton Sleeves
95 mm Stroked Crank
Bore and Honed
Step Deck
New oil Pump
New water pump
Assembly
Note*All Prices include block core, factory oil pump, new bearings, trust washers, new factory water pump, new factory seals, hot tanking of all blocks, resurfacing, blue printing, boring, balancing, decking the block, and assembly.
Note*All blocks are crated and do not come with, alternator, a/c, exhaust manifold, factory mounts, oil pan and rear bracket.
Note*All blocks are for off road use only and are not intended for Highways use, all race blocks have no warranty do to the fact that they are intended for race purposes.
ALL SPARK RACING TURBO KITS 10% OFF
All B-Series Turbo Kits $2850 shipped
Spark Racing 4 into 1 SUS304 Stainless Steel Equal Length Tubular turbo exhaust manifold
ITS/Turbonetic T3/T04E Turbocharger assembly 60 trim / Stage III
Tial Waste gate 35mm (8.7 PSI Spring)
Precision Front Mount intercooler w/ polished cast aluminum end tanks 29x10.5x2.5
BLITZ or HKS Blow Off Valve
Spark Racing Aluminum Intercooler Charge Piping
Spark Racing Mandrel bent 2.5” high flow down pipe
Spark Racing waste gate dump tube l
255 gph High pressure/High volume intake fuel pump
Vortech Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass (Missing Link)
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and T-Bolt clamps
All necessary gaskets
Installation manual
ALL SPARK RACING/ RS PORT AND POLISHED HEADS 10% OFF
B16A:
Street:
Price: $1400.00 price includes core
Street application ported and polished
Stainless Steel Valves
Three angle valve job
Full Race Springs
Titanium Retainers
Chromoly Valve seats
Full Race:
Price: $1600.00 price includes core
Full Race application ported and polished
Oversized Stainless Steel Valves
Full Race Springs
Titanium Retainers
Custom Combustion Chamber
B18C:
Street:
Price: $1550.00 price includes core
Full Race Springs
Titanium Retainers
Full Race:
Price: $1750.00 price includes core
Full Race Springs
Titanium Retainers
H22A:
Street:
Full Race Springs
Titanium Retainers
Full Race:
Full Race Springs
Titanium Retainers
Note*All Prices include cylinder head core, new factory seals, hot tanking of all cylinder head core, resurfacing and assembly.
Note*All cylinder head are crated cylinder head and do not come with, intake manifold, injectors, distributor, throttle body, exhaust manifold, and v-tec solenoids
Note*All cylinder head are for off road use only and are not intended for Highways use, all cylinder head have no warranty do to the fact that they are intended for race purposes.
ALL GREDDY PRODUCTS 25% OFF
ALL RS SLEEVED BLOCK PM PRICE TO LOW TO LIST
Proud Sponsor:'Bisi Ezerioha
INNOVATIVE TURBOS STARTING AT $650 SHIPPED
TURBONECTIC T3/TO4E TURBOS $620 SHIPPED
B-SERIES SPRING AND RETAINER KITS $245 SHIPPED
DC PRODUCTS 25%OFF
AEM 25% OFF
ARPHEADSTUDS$105SHIPPED
EAGLE RODS $285 SHIPPED
SPARK RACING RODS $225 SHIPPED
ARIAS SHELF PISTONS $420 SHIPPED
ACL BEARINGS RODS MAINS THRUST WASHERS $95SHIPPED
TYPE R OIL PUMPS $125 SHIPPED
DRAG TURBO KITS $2650 SHIPPED up
TIAL WASTEGATES $200SHIPPED
310CC & 440CC INJECTORS $220 SHIPPED
EDELBROCK VICTOR X MANIFOLDS $310 SHIPPED
EDELBROCK PRODUCTS LOWEST PRICE JUST PM
AEM INTAKES & COLD AIRS LOWERS PRICES JUST PM
APEXI USA VAFC 320 SHIPPED
AEM FUEL REGULATORS $155SHIPPED
BUDDY CLUB CAMS ALL SPECS $480 SHIPPED
ITR PISTONS W/ RINGS $149.95 SHIPPED
CP PISTONS $480 SHIPPED
I WOULD LIST EVERYTHING BUT YOU PROBALLY WOULDN’T READ IT SO EVERYTHING ON SALE NAME BRAND OFF BRAND YOU NAME IT I GOOD IT FROM GREDDY HKS AND BLITZ TO BLOX ZENKI AND CK WILL NOT BE UNDERSOLD DURING THE HOLIDAYS WE HAVE THE BEST PRICES BEEN DOING THIS FOR OVER 10 YEARS ITS TIME TO SHOW EVERYONE SUP
HAPPY HOLIDAYS GOOD LUCK WITH ALL YOUR PROJECTS AND DON’T DRINK AND RACE ![/B]
Modified by SPARK RACING INC. at 5:40 PM 12/20/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaebekae »</TD></TR><TR><TD CLASS="quote">how much for TEIN SS for the RSX
lowest quote i got was for $1080 through Stage Performance</TD></TR></TABLE>
You have pm.
You have pm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj02 »</TD></TR><TR><TD CLASS="quote">how much for apexi s-afcII?
lowest quote i got, truehonda 276.00 shipped</TD></TR></TABLE>
I can match it but that price is not very legit most likely is grey market Apexi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaebekae »</TD></TR><TR><TD CLASS="quote">for some reason i cant use pm's yet. could you email me?
Thats becuase you a trial users you can email me at sales@sparkracing.com
</TD></TR></TABLE>Thats becuase you a trial users you can email me at sales@sparkracing.com
Retired
Dec 20, 2004 04:38 PM
