Weird rattle from engine under load. WTF.
Old Dec 16, 2004 | 04:40 PM
notstock93's Avatar
Default Weird rattle from engine under load. WTF.
Just like the title says. Under 2.5k the engine has a strange rattling when at large throttle openings. It goes away when revved higher, and seems to do it with the clutch in or out (cant really tell, engine revs too quickly out of gear).
The engine runs strong, gets great mileage and only has 5-6k on it after a total rebuild. Could this be valves way out of lash? Maybe it has something to do with the GSR dual stage manifold?
I have no heat shields, no cat, and its not from the shifter area, its from the engine. Since its only under load, I only hear it while in the car- but it sounds like its coming from the transmission area toward the rear.
The rattle sounds like an exhaust heat shield rattle, if that helps any.
EDIT- It sounds alot like a rock getting vibrated in the bodywork of the car. Ive checked.....nothing
Modified by notstock93 at 2:38 AM 12/17/2004
Old Dec 16, 2004 | 05:18 PM
SkRiBLaH's Avatar
Default Re: Weird rattle from engine under load. WTF. (notstock93)
the rattling you hear is DETONATION.
check your timing ASAP before you distroy your engine.
IN VTEC's Avatar
But it's kinda dull sounding?
Could be pinging.
Old Dec 16, 2004 | 05:29 PM
notstock93's Avatar
Default Re: Weird rattle from engine under load. WTF. (IN VTEC)
Its not detonation, my engine has a knock sensor, and im only running 10.5:1 on 91. Its also running Hondata and im not a complete ****-tard. its not a "ping" its a rattle.
Besides, its a mechanical sound, like an exhuast rattle. If hadnt taken off all my heatsheilds if blame them.
its not dull, it sounds very clear, just not very loud. Like metal against metal vibrating.
EDIT- timing is @ 17 degrees BTDC
Old Dec 16, 2004 | 05:46 PM
thatbluecrx's Avatar
try the bracket that has 2 bolts to secure the bottom of your header
Old Dec 16, 2004 | 06:01 PM
notstock93's Avatar
Default Re: Weird rattle from engine under load. WTF. (thatbluecrx)
I will be replacing my header soon with a one-piece big-collector header.....so we'll see if that's the case.
If its not detonation (and its not-its been doing this since the engine was rebuilt a year ago) then what could it be. Something out of whack in the head? Rock in the tranny? muffler bearings going bad? I mean....its not the noise that's bothering me, its not knowing what causing it that gets me.
Im starting to suspect the intake piping or the header.....more insight please.
Old Dec 23, 2004 | 06:58 PM
Shaun's Avatar
this is happening with me2 , anyone?
Old Jan 2, 2005 | 07:59 AM
TegoDC5's Avatar
Default Re: (Shaun)
I have the same thing, happens at 1500 rpms for me, weird thing is....it only happens at exactly 1500 rpm's....
Old Jan 2, 2005 | 08:47 AM
psychotic_z's Avatar
Default Re: (Daddy Yankee)
My DA rattles like a old army tank. Join the club. I had some rattles that I never figured out, but you'll find that attaching all wires and clips in your engine to their appropriate places cures some, heatshields cause some, and if you have a short shifter, the bottom of the shifter may be touching the exhaust pipe.
Old Jan 2, 2005 | 10:13 AM
Shaun's Avatar
turns out I had a hole in my header the size of a snicker bar, length and width
Old Jan 2, 2005 | 03:26 PM
notstock93's Avatar
Default Re: (psychotic_z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic_z &raquo;</TD></TR><TR><TD CLASS="quote">My DA rattles like a old army tank. Join the club. I had some rattles that I never figured out, but you'll find that attaching all wires and clips in your engine to their appropriate places cures some, heatshields cause some, and if you have a short shifter, the bottom of the shifter may be touching the exhaust pipe.</TD></TR></TABLE>
My wires are fine, the heat shelids are gone and my shifter is stock (it rattles a bit, but thats not what im talking about).
It may be the header, I still have yet to change it out for the good one I have.
Old Jan 2, 2005 | 04:01 PM
STREETWERKZ's Avatar
this just happened to me.....
it was a LOOSE O2 sensor, it wasnt tightened all the way.
Old Jan 2, 2005 | 05:48 PM
notstock93's Avatar
Default Re: Weird rattle from engine under load. WTF. (STREETWERKZ)
I keep on thinking its something like the pistons rattling inside the block (and yea, I know that there is no way in hell that's it)
More likely- I have a "too loose" bolt somewhere in the engine bay that's vibrating under load.
Old May 31, 2005 | 10:41 AM
notstock93's Avatar
replaced header with long-tube one peice, replaced 02 sensor secured everything down tight, and it STILL rattles.
Anyone have any experiance with a water-pump rattling?
EG-SIXV-TEC
Sep 6, 2010 05:12 AM
explosive
Jan 20, 2009 07:39 PM
Shaun
13
Dec 27, 2004 12:04 PM
2000 Integra R #760
Jan 19, 2003 09:17 AM
