i need sway bar suggestions
Old Dec 16, 2004 | 04:10 PM
prettypurple6218's Avatar
Default i need sway bar suggestions
hey guys!
okay im new at this.....well i have a 99 accord coupe with tein basic....my car has a lot of body roll and i want to eliminate that cuz i plan to autox....so im looking to get sway bars and i wanted to know any suggestions you might have.
thank you for any info you can give me.
Old Dec 16, 2004 | 04:11 PM
-RedneckDave-'s Avatar
Working
Default Re: i need sway bar suggestions (prettypurple6218)
ST sway bars are great. You can use the bars from a CL-S but If you are going to be auto-xing then I would say go with the ST bars.
Old Dec 16, 2004 | 05:10 PM
98carbonaccord's Avatar
Default Re: i need sway bar suggestions (-RedneckDave-)
for best bang for buck go with oem
the '04 TL 6-speed sway is 20mm, the previous model CL/TL type S is 19mm.
the 04 tl speed sway will fit on all usdm accords 98-04
04 TL sway part #'s:
52300-SEP-A11 - Rear Sway Bar (called a spring by acura/honda)
52306-SEP-A11 - Bushing (2 needed)
52308-SEP-A00 - Holder for bushing (2 needed)
CL/TL Type S sway part #'s:
52300-S3M-A01 - Rear Sway Bar
52306-S0E-015 - Bushing (2 needed)
52308-S3M-A00 - Holder for bushing (2 needed)
BTW, if you have a DX accord, you need to purchase ENDLINKS for your rear sway bar
Old Dec 16, 2004 | 05:48 PM
Default Re: i need sway bar suggestions (98carbonaccord)
DIY (if needed):
http://www.filtsai.com/accord/...2.php
Popular Sway Bar Sizes:
CL/TL-S - 27.2mm f / 19mm r
Neuspeed - 27mm f / 19mm r
ST - 27mm f / 19mm r
Eibach - 27mm f / 23mm r
Comptech - 27mm f / 23mm r
f = front
r = rear
Old Dec 16, 2004 | 05:52 PM
-Bionic-'s Avatar
Former Sponsor
Eibach sway bars are business.
Old Dec 16, 2004 | 05:55 PM
Default Re: i need sway bar suggestions (-Bionic-)
strubars will also help prevent body roll
id recommend neuspeed, or CL-S/TL-S, or comptech if you can afford it
basically, dont get any strut bar with holes in it (DC) or any strut bar that is weak and flexible (ebay brands), you want a strut bar that is STRONG and FIRM
Old Dec 16, 2004 | 06:20 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98carbonaccord &raquo;</TD></TR><TR><TD CLASS="quote">id recommend neuspeed, </TD></TR></TABLE>
Yeah the Neuspeed strut bar is nice, and it's one solid piece, and not a three piece like the majority of strutbars out there.
But if you want to work on roll, then get the swaybars. My current setup is Eibach front and rear swaybars, and Neuspeed front upper and lower tiebar. A decent setup. The tein ss also stabilizes the car.
Old Dec 16, 2004 | 07:09 PM
azian21485's Avatar
just get a s/t rear swaybar and call it a day...you won't need the front..especially with the spring rates that come with the basics...you'll end up understeering heavily
Old Dec 16, 2004 | 07:13 PM
Default Re: i need sway bar suggestions (azian21485)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">just get a s/t rear swaybar and call it a day...you won't need the front..especially with the spring rates that come with the basics...you'll end up understeering heavily</TD></TR></TABLE>
why pay over $100 for an S/T rear sway bar when you can get a CL-S/TL-S rear sway (same size 19mm) for about $50 (with bushings and brackets) from the dealership?
or you could get a 20mm for around $50 too?
Old Dec 16, 2004 | 09:54 PM
EK4civichatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98carbonaccord &raquo;</TD></TR><TR><TD CLASS="quote">strubars will also help prevent body roll
basically, dont get any strut bar with holes in it (DC) or any strut bar that is weak and flexible (ebay brands), you want a strut bar that is STRONG and FIRM </TD></TR></TABLE>
Strutbars do nothing for bodyroll. They are only supposed to stiffen the chassis, in affect allowing the suspension to work better. Sway bars on the other hand DO.
Old Dec 17, 2004 | 01:08 AM
azian21485's Avatar
or you could get a 20mm for around $50 too?</TD></TR></TABLE>
because most oem bars are hollow and don't come with polyurethane bushings
Old Dec 17, 2004 | 03:20 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">because most oem bars are hollow and don't come with polyurethane bushings</TD></TR></TABLE>
I do believe you can buy the poly bushings seperately.
Unless the S/T bar is adjustable, then I would just go with the OEM.
Also, I'm having a brain fart and can't remember the advantage or disadvantage of a solid or hollow sway bar. Could someone explain that again real quick. Thanks
Old Dec 17, 2004 | 11:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 &raquo;</TD></TR><TR><TD CLASS="quote">because most oem bars are hollow...</TD></TR></TABLE>
not the rear sways, i dont know who told you that??
Old Dec 17, 2004 | 11:33 AM
Default Re: i need sway bar suggestions (EK4civichatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK4civichatch &raquo;</TD></TR><TR><TD CLASS="quote">Strutbars do nothing for bodyroll. They are only supposed to stiffen the chassis, in affect allowing the suspension to work better. Sway bars on the other hand DO.</TD></TR></TABLE>
ur right, i dont know why i thought that about strutbars
Old Jul 28, 2005 | 01:00 PM
slomob18b's Avatar
I have a 98 4dr LX with a 18mm rear swaybar. Will that 1 or 2mm make that much of a difference? I also know that the 98-02 Accord V6 coupes has the 19mm rear swaybar.
Old Jul 28, 2005 | 05:00 PM
jmal1919's Avatar
You know if any of the the TL sway bars would work on a 02 accord with a 3" exhaust?
Would I see any benifit to getting one with the stock suspension? I plan to eventually get coilovers, but I'm kind of waiting for my stock struts to go bad.
88browncow
Jan 28, 2011 06:15 PM
Partizan
Northern California (Sales)
Feb 20, 2008 06:45 PM
K24.20A
Feb 14, 2007 03:52 PM
DarkBB4
Feb 1, 2006 01:16 PM
