skunk 2 Im install.....
Old Dec 16, 2004 | 02:29 PM
h22a193's Avatar
Default skunk 2 Im install.....
yea so I niticed there is quite of few things needed to be changed over when switching... I have the manifold sitting in the garage waiting to be dropped in, just wondering if you guys had any info on the install..
Old Dec 16, 2004 | 03:29 PM
prelittlelude's Avatar
Default Re: skunk 2 Im install..... (h22a193)
your probably one of the first few on the board that will do the install, it hasn't been out that long, maybe someone from the civic forum will roll in here that has done this in their hybrid
Old Dec 16, 2004 | 03:41 PM
@ries's Avatar
https://honda-tech.com/zerothread?id=964311
Old Dec 16, 2004 | 04:03 PM
98TypeSH's Avatar
Default Re: skunk 2 Im install..... (@ries)
lol i did the install in a few hrs on my 5th gen type SH.
you gonna need to swap all sensors, TB, and IACV. Good luck with the damn intake temp sensor that damn thing is in there so good. Make sure you dont strip the screws or you will be kicking yourself. have a good time, its a major pain in the ***.
Old Dec 16, 2004 | 05:56 PM
VSBB6's Avatar
Default Re: skunk 2 Im install..... (98TypeSH)
I recommend you also install hondata gasket at the same time, it took me two hrs just to clean up the old paper gasket sticking on the head.
Old Dec 16, 2004 | 06:01 PM
prylwd's Avatar
Default Re: skunk 2 Im install..... (VSBB6)
I agree. If you have the money get the hondata gasket b/c your already doing the labor.
Old Dec 16, 2004 | 08:16 PM
95ONE's Avatar
Channel locks clamped around the tip takes them off quickly. The lock washer really does its job on that sensor.
Idle air control valve doesn't really need the coolant line, so just don't hook them up. (Coolant lines) Fast idle valve mounted on the firewall would be best. It requires the coolant lines and is best off the intake manifold. ya know. While your there....
Old Dec 17, 2004 | 04:20 AM
TypeR0207's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VSBB6 &raquo;</TD></TR><TR><TD CLASS="quote">I recommend you also install hondata gasket at the same time, it took me two hrs just to clean up the old paper gasket sticking on the head.</TD></TR></TABLE>
Not to be a thread *****/stealer ............ but what advantage does putting on the Hondata gasket give you?? I have heard of this, but have no idea why to do it ....
Old Dec 17, 2004 | 05:48 AM
pentaq's Avatar
Default Re: skunk 2 Im install..... (TypeR0207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR0207 &raquo;</TD></TR><TR><TD CLASS="quote">
Not to be a thread *****/stealer ............ but what advantage does putting on the Hondata gasket give you?? I have heard of this, but have no idea why to do it ....</TD></TR></TABLE>
It lowers intake temp by insulating mani from head.
Old Dec 17, 2004 | 05:59 AM
TypeR0207's Avatar
Default Re: skunk 2 Im install..... (pentaq)
So is it thicker then? And a different material other than the usual Honda stock one?
Old Dec 17, 2004 | 06:01 AM
Sam1am26's Avatar
Yeah it is way thicker and uses a plastic-like insulating material....
Old Dec 17, 2004 | 06:21 AM
v4lu3s's Avatar
RTFM
and it is also reusable and wont stick to teh metal like a paper gasket.
Old Dec 19, 2004 | 04:23 AM
h22a193's Avatar
Default Re: (v4lu3s)
ok I got it in, now just hooking up heres and theres..... Im not running any coolant to the mani, as for the iat sensor, had to cut a slot in the screws to get them out.... My fast idle valve was blocked off from long ago ( coolant bypass mod) I think Im ready to go, cranking it up today...
Old Dec 19, 2004 | 07:48 AM
mgags7's Avatar
ill admit it, this is thread jacking so put your hands up....hahah
on the topic of the iacv not needing the coolant lines, is this actually true? what purpose do they serve it now?
i dont want idle bounce though so if that will do it dont bother explaining....
Old Dec 19, 2004 | 08:07 AM
h22a193's Avatar
Default Re: (mgags7)
the iac doesnt need them, just block it and route the line back the therm housing
Old Dec 19, 2004 | 08:12 AM
mgags7's Avatar
will i get idle bounce like this though?
also, without the coolant lines through the iacv and the thermo valve blocked off will my car idle higher when its cold still?
Old Dec 19, 2004 | 09:32 AM
Sam1am26's Avatar
I have always not had had coolant lines hooked up to my IAC and my motor idled beautifully...
Old Dec 19, 2004 | 09:45 AM
matix's Avatar
Default Re: (Sam1am26)
Good to hear i wasnt the only person that had to cut off the old screws on the iat sensor.
Old Dec 19, 2004 | 10:03 AM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">on the topic of the iacv not needing the coolant lines, is this actually true? what purpose do they serve it now?</TD></TR></TABLE>
The coolant lines keep the IACV from freezing in cold weather. It matters your climate if you can loop them or not.
Old Dec 19, 2004 | 10:46 AM
h22a193's Avatar
yea it idles like normal, fast on cold start till warm, then works fine...
also any input on those hole in the back right of the manifold, do they go to anything? Im just gonna plug them, I have no use for them
si_pinoy
Honda Civic (2006 - 2015)
Nov 30, 2008 04:11 PM
InTeGrA GsR 321
May 5, 2005 10:55 PM
ActiveAero
Sep 18, 2002 01:39 PM
