sleeved boring..
Old Dec 16, 2004 | 01:45 PM
riley_rb_34's Avatar
Default sleeved boring..
Hey everybody, if i sleeve my b16 what's the most i can reliably bore it to with a full engine build at 11:1 designed to normally redline at about 8k? I was thinkin 85mm but correct me if i'm wrong. thanks
Old Dec 16, 2004 | 03:35 PM
Darton Sleeves's Avatar
Default Re: sleeved boring.. (riley_rb_34)
You would need to sleeve the block to be able to go to a 85mm bore. You best bet is to start at 84mm so down the line if you run into problems you have room to bore to the next size or use the sleeves in another block if your current one gets damaged.
Old Dec 16, 2004 | 04:40 PM
thanks...guess i'll go 84mm....if you're lucky i'll even buy Darton
delsol8017
Nov 7, 2019 08:00 AM
12secdc2
Dec 4, 2008 09:25 PM
EFin' Kyle
Mar 5, 2006 01:13 PM
otto
Aug 17, 2004 06:36 PM
