Can't get crankshaft pulley bolt off
Old Dec 16, 2004 | 01:07 PM
FairlightRacing's Avatar
Default Can't get crankshaft pulley bolt off
I have a JDM B16A1 in my 90 CRX Si. I cannot get the 19mm crankshaft pulley bolt off. Tried a big *** breaker bar, no go. Tried my Ingersoll-Rand 2135TI with 700ft-lbs of torque, no go.
Put some WD40 and later some liquid wrench type stuff on it again. Hit it with another 700ft-lbs from the Ingersoll. Still won't f*cking budge. How the hell am I going to get this off? I need to change my timing belt soon before it breaks.
Any in the Seattle area work at a machine shop with a 1 inch drive impact wrench with 1200ft-lbs or more of torque?
Old Dec 16, 2004 | 01:35 PM
Rod.'s Avatar
Default Re: Can't get crankshaft pulley bolt off (FairlightRacing)
get a flywheel holder and try to break the nut
Old Dec 16, 2004 | 01:36 PM
eda6's Avatar
Default Re: Can't get crankshaft pulley bolt off (redturbocivic)
Try tightening a little and then loosening it again.
Old Dec 16, 2004 | 01:38 PM
Jowee's Avatar
I have this impact from Sears that has removed every bolt I needed. If that doesn't work, get a 5-6 ft long pipe and use that on your breaker bar with a big fat guy on the end of it.
http://www.sears.com/sr/javasr...05000
Old Dec 16, 2004 | 02:05 PM
Default Re: Can't get crankshaft pulley bolt off (ITR 98 1162)
I had trouble taking the 17mm crankshaft pulley bolt off my D16A6 too. Even after his a 13 foot antenna poll and liquid wrench. That is why I originally bought the Ingersoll-Rand 2135TI. The 2135 ripped the bolt right off with ease. It was unbelievable. And it has got every other bolt no matter how tight.
Something is up with this 19mm. I am too the point where I may have to drill it out. I mean if the biggest, baddest 1/2in drive impact wrench can't take it off, nothing will. Still hoping some one has a 1 in or bigger impact wrench. Like the one you would use to do the bolts on a steel power poll (the big *** 4 in lugs ).
Old Dec 16, 2004 | 02:44 PM
Jowee's Avatar
Sounds pretty bad. Did you double check and make sure you're getting about 90 PSI through the air hose to the gun?
Old Dec 16, 2004 | 02:51 PM
92HB_HB's Avatar
you gotta make sure the crank isn't slipping when u use theimpact gun cuz w/ the crank moving, its just acting as a dampener and absorbing the impact blows.. also depending on if the motor is till in the car will determine the severity of the situation..
That pully bolt shouldn't be a problem at all.. Just put some elbow grease into it..
Old Dec 16, 2004 | 04:07 PM
boost'd_crx's Avatar
i had the same problem. i used an 1in ir impact and it came off like nothing. the gun was probably 1000ft-lbs
Old Dec 16, 2004 | 05:43 PM
PrettyLude's Avatar
sounds like someone dipped the crank pulley bolt in a big can of loctite, try using a 1" impact gun
Old Dec 16, 2004 | 06:26 PM
tegmech's Avatar
we had about a 8 foot breaker bar on cyphears car when we took his off. i jumped on the bar a couple times and it came right off.
Old Dec 16, 2004 | 07:27 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">I have this impact from Sears that has removed every bolt I needed. If that doesn't work, get a 5-6 ft long pipe and use that on your breaker bar with a big fat guy on the end of it.
http://www.sears.com/sr/javasr...05000</TD></TR></TABLE>
i had trouble gettin the one off my ls with a very similar craftsman airgun. i cheated a little and turned the psi in the hose from like 90 to 110-115 and it came off immediately.
ive also had a 4+ foot pipe and a rather large friend break stuff loose for me before. id prefer the air impact gun any day
Old Dec 16, 2004 | 08:47 PM
Bailhatch's Avatar
Default Re: Can't get crankshaft pulley bolt off (blackeg)
If you heat up the thick washer behind the bolt it will come off easily with the 700ftlb gun. Get it very hot very quick and you should be fine. The mass of the crank will take the heat away pretty fast so don't worry too much about hurting the front seal or anything. I woulden't get it red hot but maybe close.
Old Dec 16, 2004 | 11:13 PM
2k.civic.si's Avatar
Default Re: Can't get crankshaft pulley bolt off (Bailhatch)
crank up the compressor pressure...ive had to run mine as high as 130psi to break some bolts loose with my impact gun
Old Dec 17, 2004 | 04:31 AM
snatch's Avatar
Default Re: Can't get crankshaft pulley bolt off (2k.civic.si)
Just like tegmech said, get a 8ft breaker bar, and just work with it. I spent awhile trying to break mine loose, but by the time you're practically hanging from the breaker bar, or jumping on it, it will break loose.
Old Dec 18, 2004 | 11:12 AM
kysard's Avatar
take off the lowershield to the flywheel, lock the flywheel by wedging a allen key in the teeth. The bolt will come out much easier
Old Dec 18, 2004 | 11:43 AM
Dragline's Avatar
They make a tool that will hold the crankpulley if you look at your crankpulley the center is hex shaped they make a tool that slides in there so you can hold it from spinning and break it loose with your breaker bar,it works everytime for me,I had the same problems before I got the tool.
Old Dec 20, 2004 | 10:09 PM
skunk2finatic's Avatar
You need to get urself a butane torch....heat up the area around the bolt for like 1 min....then torque it off with ur impact.....Honda uses locktight on there crank bolts from factory.... I did it this way tonight and it came of right quick.
Old Dec 21, 2004 | 04:13 AM
SupaFly_Honda's Avatar
they make a special hex tool to hold the pulley from turning. Look into it.
Old Dec 21, 2004 | 06:49 AM
Chain Driven's Avatar
Default Re: Can't get crankshaft pulley bolt off (SupaFly_Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2finatic &raquo;</TD></TR><TR><TD CLASS="quote">You need to get urself a butane torch....heat up the area around the bolt for like 1 min....then torque it off with ur impact.....Honda uses locktight on there crank bolts from factory.... I did it this way tonight and it came of right quick.
works every time we do this daily
Old Dec 21, 2004 | 12:56 PM
msmotorsports's Avatar
Default Re: Can't get crankshaft pulley bolt off (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">They make a tool that will hold the crankpulley if you look at your crankpulley the center is hex shaped they make a tool that slides in there so you can hold it from spinning and break it loose with your breaker bar,it works everytime for me,I had the same problems before I got the tool.</TD></TR></TABLE>
You need this wrench. Even though it costs around $60-80 it is very worth it. You will definitely get it off with the tool. I wouldn't suggest putting a allen key in the flywheel as you can crack the tranny casing or damage the starter teeth on the flywheel. Moroso makes the crank pulley wrench. You can get it on Summit or Jegs.
Old Dec 21, 2004 | 10:07 PM
Default Re: Can't get crankshaft pulley bolt off (msmotorsports)
Naaa....what he needs is not too spend another dollar on crap he's not going too use.....Just get a 5 dollar torch....heat it up...bust it off with 90psi and ur done... and all under 5 bucks...and it's full proof, no doubt
Old Feb 7, 2005 | 06:51 AM
tealbubble's Avatar
Default Re: Can't get crankshaft pulley bolt off (skunk2finatic)
bringing this thread back to life....
i've tried heating with torch even till red....impacts... breaker bars.. using the starter to break it loose. and the pulley hasnt turned either is the tool worth the money to hold the crank if nothing else has worked??? i need to install a new crank fluctuation sensor... any help would be great thanks...
Old Feb 7, 2005 | 09:49 AM
tealbubble's Avatar
HELP TTT
Old Feb 7, 2005 | 12:58 PM
PrettyLude's Avatar
get that tool
Old Feb 8, 2005 | 06:50 AM
jweller's Avatar
Default Re: (PrettyLude)
buy the tool. I got mine for less than $50 shipped. it is worth every penny.
my IR impact with 650 lb/ft in reverse couldn't get it. but I got it with that tool and 2 18in breaker bars. you just need constant steady pressure
