New to the forum. Need some input on where to start.
Old Dec 16, 2004 | 12:59 PM
Chris94Hatch's Avatar
Default New to the forum. Need some input on where to start.
I have acquired a 94 CX hatch. It is a fun little car but has a lot to be desired.
I am looking into doing FI in the next little bit but want to make sure I get my info straight.
I believe the car has a D15b8? Please correct me if I am wrong on this. I would like to know if the sohc vtec head is swapable onto this motor for starts as boosting a 70hp motor is useless IMHO.
Help me out. There seem to be some knowlegable people on this board. I don't want to buy anything untill I have a full plan. I made that mistake once before with my RX-7 and I have way over invested in it now.
So what are my options Preferably without removing the bottom end. Car has 60,000 Miles on it and I bought it as a daily driver.
Thanks,
Chris
Old Dec 16, 2004 | 01:11 PM
delslo93's Avatar
Default Re: New to the forum. Need some input on where to start. (Chris94Hatch)
Hey chris...
i just recently swaped a vtec head onto my del sol that had a d15b7 in it. I must say that it added an butt load of h.p. (though the head also was port and polished with a 3 angle valve job) The swap is very easy and will cost you around $400 or so probably because you will need an si distributor, timing belt, ecu, the head, different plug wires, a new head gasket, oil, anti-freeze, valve cover gasket, and exhaust gasket. Just use the search function and find all the details on how to do the swap. As for boosting i am just about to boost mine as well. The bad thing is this swap leads to a very high compression that isnt liked by boost. But with a good tune boosting just about anything is possible. If you want to save money i would do like i am doing and make a do it yourself kit which include a lot of DSM stuff and stock honda civic hf manifold with an adaptor plate. Use the search function on the site and look up do it yourself turbo kits.
OmgDelSol
28
Jan 25, 2012 03:47 AM
NewfieAccordEXR
Jul 20, 2005 02:18 PM
JoltTheSpud
Mar 7, 2005 01:15 PM
Acura Soundz
Nov 1, 2001 06:19 AM
