bkr7e or bkr8e
first off, its recomended to run 2 steps colder than the stock heat range right?
so im wondering, if the stock h22 heat range is 6, shoul i go with the 7's or 8's
im going to be running around 12psi on the street (since my w/g spring is a .7bar) and around 15-18psi at the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid »</TD></TR><TR><TD CLASS="quote">Just to add to ladysman post:
6's: 300-350whp level
7's: 350whp-450whp level
8's: 450whp-600whp level
12psi would put me in place for the 7 heat range, but 15-18psi would put me in the 8 heat range.
so, since my stock heat range is already 6 should i go with 7's or 8's?
most people are saying go with the 7's but thats only ons step colder, will that be ok?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 »</TD></TR><TR><TD CLASS="quote">im running the 7's....
same here
</TD></TR></TABLE>same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C »</TD></TR><TR><TD CLASS="quote">ZFR6F-11's here
Those have worked up to 14lbs for me.</TD></TR></TABLE>
is that only 1 step colder for you?
Those have worked up to 14lbs for me.</TD></TR></TABLE>is that only 1 step colder for you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nlc »</TD></TR><TR><TD CLASS="quote">
is that only 1 step colder for you? </TD></TR></TABLE>
Yep.
Yep.
Stupid question but what plug manufacturer are those part numbers from? I've been running a set of OEM plugs re gapped with no problems up to 11 psi. But, it's about time for me to start looking for a "safer" set.
you should be able to have NAPA or Schucks order them for you. check out http://www.NGK.com for the stock number and just give that to the counter guy.
EDIT: I checked the NGK side and they don't make ZFR8F-11 or the BKR8E.
I would just go with the ZFR7F-11's gapped at .035 and call it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">IDK man, Jeff threw some 8's in my b16, because it's 11.0 to 1 compression. . .
And with 93 octane I'm only making 265whp. . </TD></TR></TABLE>
starting to lean toward 7's b/c i have 9.5:1 compression, but dont feel safe b/c its still only 1 step colder ahhh!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 »</TD></TR><TR><TD CLASS="quote">ngk stock num 5238
r5671a_9
the best plug ever for turbo bit cold but i made 519whp on pump 91 octane with those and there cheep and worth every penny </TD></TR></TABLE>
anyone else?
r5671a_9
anyone else?
r5671a_9
I tried these plugs out and my friend runs these plugs in his 2.0l turbo gsr pushing out 600+whp. The only thing bad about running such a cold plug is it can flood out really easy during cold starts. Other than that, it's great.
r5671a_9
Those are the Stock replacement plug type. They have the extended tip which sticks the plug into the combustion chamber more. The BkR/BPR____ are the non extended tips. The extended tips are more condusive to Pre-ignition.
I wouldnt Use the Stock heat range plus if your turbo regardless.
The Colder plugs foul a bit quicker, but its well worth the 8$ spark plug change
</TD></TR></TABLE>Those are the Stock replacement plug type. They have the extended tip which sticks the plug into the combustion chamber more. The BkR/BPR____ are the non extended tips. The extended tips are more condusive to Pre-ignition.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg »</TD></TR><TR><TD CLASS="quote">
I tried these plugs out and my friend runs these plugs in his 2.0l turbo gsr pushing out 600+whp. The only thing bad about running such a cold plug is it can flood out really easy during cold starts. Other than that, it's great.</TD></TR></TABLE>
well its 18 degrees here in utah and my car starts on a dime with no props but like u said i will change my plugs out more offten than normal ofcourse but there great plugs im a ngk dealer and can get any plug someone needs
