Is it worth it?
Old Dec 16, 2004 | 11:05 AM
CivicHB89's Avatar
Default Is it worth it?
I have a 1989 Honda DX, not sure, but from what everyone tells me, im going with it. It has a d15b2 engine in it. I dont have the money to swap in a better engine. So i was wondering if this engine is worth putting money into? or if it even has the potential to be somewhat fast? Also what is the Stock HP it has? I have about $700 coming to me, i know its deffanitly not enough to be supping up an engine really good, but enough to get going. Thanks
Old Dec 16, 2004 | 11:08 AM
301am's Avatar
nope not worth it.
Old Dec 16, 2004 | 11:10 AM
Recluse03's Avatar
it'll be a decent daily driver, but you WILL NOT be able to make that engine anything mroe than that really.
Old Dec 16, 2004 | 11:11 AM
CivicHB89's Avatar
Default Re: (Recluse03)
Damn...Not what i wanted to hear...lol oh well..What would be a preferable (sp?) engine i could pick up cheap from a junkyard?
Old Dec 16, 2004 | 11:22 AM
CRX Toad's Avatar
Default Re: (CivicHB89)
d16 from 88-91 Si, but you'll have to rewire....I know your pain...also run a search lots of good engine swap threads out there
Old Dec 16, 2004 | 12:06 PM
ServiceAdvisor's Avatar
If you want decent power at a cheap price get a ZC. SOHC or DOHC, they are so damn cheap. Call around to engine/trans sellers, you just have to wire for PGMFI your set. You can keep your tranny, axels, easier to get a new engine harness. Just pick up a new manifold off maybe a same year Si and then just bolt it on. You can even keep your AC. Go to http://www.thezcr.com for more info on ZCs. - Darrell
Old Dec 16, 2004 | 12:13 PM
DaX's Avatar
DaX
Loved
Community Favorite
D15B2 puts out about 90hp stock. Great for mileage, not for performance.
Old Dec 16, 2004 | 01:06 PM
CivicHB89's Avatar
Default Re: (DaX)
Thanks for all the reply's and info everyone! Damn only 90hp? haha what a turd of a motor.
Old Dec 16, 2004 | 01:15 PM
CivicHB89's Avatar
One more question..What is the difference between my d15b2 engine and a ZC d15b2 engine?
Old Dec 16, 2004 | 01:27 PM
wompwomp61's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHB89 &raquo;</TD></TR><TR><TD CLASS="quote">One more question..What is the difference between my d15b2 engine and a ZC d15b2 engine?</TD></TR></TABLE>
there's no ZC d15b2
ZC's are just jdm versions of the usdm stock ef si motor.
like dohczccrxsi said there's a dohc, and a sohc. they put out 130 and 120 hp respectively. bottom line. you're gonna want to switch to pgmfi..which i hear is a bitch and a half, but 100% worth it. then you're gonna want that new motor. you can pick up a zc or even a regular si motor for pretty damn cheap. i'm talking CHEAP. the results are gonna be very worth it, too. i just drove a friends civic std. and that thing was a pig. he drove mine and it blew his mind..given my car isnt all that quick. but anything is quicker than what you've got in there now. good luck with your endeavors!
Old Dec 16, 2004 | 01:35 PM
31flavorscivic's Avatar
Default Re: (wompwomp61)
A friend of mine did that one thing previously mentioned where he took off the stock intake manifold on the d15b2 and shoved an SI one on there, bumped the HP by about 10-15. Thats another option, but personally I would do ZC. It is one of the cheapest, easiest swaps to do. You could probably do it for about 400-600$ if you kept your stock tranny. Also bolts directly in
Old Dec 16, 2004 | 01:37 PM
Robster Craw's Avatar
Default Re: Is it worth it? (CivicHB89)
sell it to me, save that and your $700 and get a decent Si or HF (which has the MFPI setup already)
Old Dec 16, 2004 | 01:41 PM
slate13530's Avatar
Default Re: Is it worth it? (K2500 Yo!)
ZC SOHC V-Tec or just plain ZC SOHC, but you might have to do some rewiring unless you find a donor Si and ****** the harness from that car.
Old Dec 16, 2004 | 01:44 PM
aaronhume's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">D15B2 puts out about 90hp stock. Great for mileage, not for performance.</TD></TR></TABLE>
yep I can agree to that... but if you really want better gas mileage, just make a nice cold air intake out of pvc pipe! w00t.... I painted mine red still no power though I'm saving up for a b16a1 motor swap.... sometime too far off...
powerpuff
Nov 1, 2013 11:50 AM
Gatnasty
Jan 15, 2009 06:13 PM
bobjohnson
Apr 22, 2008 04:54 PM
