General internal cleansing question.... would appr.some opinions
Old Dec 16, 2004 | 11:01 AM
D-series ninja
Guest
Posts: n/a
Default General internal cleansing question.... would appr.some opinions
ok so i ended up getting a motor out of a gsr that was burnt to the ground.. i have since replaced all sensors, dizzy, hoses etc... i proceeded to take the valve cover off and there was all that white **** from the fire extigusher in the head. not alot but there was some... drained the oil, water in the oil from the fire hoses...got all the water out and put some crappy plugs back in for the time being..
my question is what would you recomend on how to clean this thing out w/o taking apart the bottom end.. could you just cycle oil through it and manually keep turning it over? or what?
im planning on having the head hot tanked just to sclean the outside of it up a little... but dont think that wil clean the inside if the head..
i would really appreciate some opinions on this one.. thanks
Old Dec 16, 2004 | 11:03 AM
.RJ's Avatar
.RJ
Default Re: General internal cleansing question.... would appr.some opinions (ef-love)
http://www.hmsmotorsport.com/s...#1522
Old Dec 16, 2004 | 11:05 AM
SlapSmak's Avatar
If yuou have the head 'hot tanked' , the solution runs into all the passages. The head completely submirsed in hot creasote of other solution and effectivly cleans everything.
Old Dec 16, 2004 | 11:22 AM
Bbasso's Avatar
Default Re: General internal cleansing question.... would appr.some opinions (.RJ)
RJ, are you being paid buy Motul to promote their products???
Old Dec 16, 2004 | 11:44 PM
D-series ninja
Guest
Posts: n/a
thanks... appreciate the tips..
keep em comin
Old Dec 17, 2004 | 05:44 AM
uNF$@#!'s Avatar
Default Re: General internal cleansing question.... would appr.some opinions (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">RJ, are you being paid buy Motul to promote their products??? </TD></TR></TABLE>
don't you know? RJ uses motul, and hell probably drinks the motul too
I wouldnt be surprised if he was the next motul authorized dealer in the USA
Old Dec 17, 2004 | 07:41 AM
The Kernel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hmsmotorsport.com/s...#1522</TD></TR></TABLE>
Is this something I should consider using at 25k miles on a stock engine?
Old Dec 17, 2004 | 08:03 AM
.RJ's Avatar
.RJ
Default Re: General internal cleansing question.... would appr.some opinions (The Kernal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Kernal &raquo;</TD></TR><TR><TD CLASS="quote">
Is this something I should consider using at 25k miles on a stock engine? </TD></TR></TABLE>
I use it and the fuel system cleaner every other oil change, but my car is driven harder than most (3500 track miles this year)
sonny0330
Nov 25, 2007 03:24 PM
aznej2
Nov 21, 2006 02:12 PM
spidermancivic
Aug 12, 2005 04:44 PM
98DC2teg
Nov 25, 2003 01:01 PM
JonGP4
Sep 23, 2003 07:21 AM
