Anything else to replace besides broken axle??
Old Dec 16, 2004 | 10:53 AM
Mario.'s Avatar
Default Anything else to replace besides broken axle??
So the outter joint broke on me while going to school, so I'll be replacing the whole driver-side axle. Is there anything else that needs to be done while doing this procedure, or is just the axle sufficient?
Old Dec 16, 2004 | 10:57 AM
Deemeetree's Avatar
Electrician
Nope. Go to AutoZone and get yourself an axle. Lifetime warranty. $75.
Old Dec 16, 2004 | 11:03 AM
Mario.'s Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Nope. Go to AutoZone and get yourself an axle. Lifetime warranty. $75.</TD></TR></TABLE>
Ok cool. So repacking bearings, replacing seals, etc. isn't necessary?
Old Dec 16, 2004 | 11:04 AM
Marauder's Avatar
Default Re: (Mario.)
Nope, just change out the axle. If your tranny fluid is old, I'd change it at the same time.
Old Dec 16, 2004 | 11:10 AM
Deemeetree's Avatar
Electrician
Default Re: (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">Nope, just change out the axle. If your tranny fluid is old, I'd change it at the same time.</TD></TR></TABLE>
I concur.
That video is nasty. Funny how the CV joint grenaded before the boot even tore. My boot is tore on both sides. Need 2 new axles.
Old Dec 16, 2004 | 11:18 AM
The Internet Tough Guy's Avatar
Default Re: (Dimi)
axle nut should be replaced. you can reuse them if you want, but after you stake that nut down a few times it gets all screwed up.
if you're using a pickle fork to seperate the lower ball joint, be careful that you don't rip it. i've done this too many times. now i use a pitman tool and it works great.
you've probably read this one https://honda-tech.com/zerothread?id=382416 by now, but if not it will certainly help you out.
Old Dec 16, 2004 | 02:25 PM
Mario.'s Avatar
Default Re: (jwn7)
Thanks a LOT guys. I'll read that up now, but the seller who sold me the car is gonna help me replace it. He's on the local Colorado forums as well which is cool.
SRd240sx
May 19, 2007 02:23 PM
97grnrs
Oct 3, 2006 02:52 PM
ahloung
15
Mar 14, 2006 11:52 AM
stealthhatch
Mar 21, 2004 09:20 AM
Smoothy
Jul 26, 2003 12:16 AM
