5 bolt DP flange on sc61
Old Dec 16, 2004 | 09:41 AM
TeamShiftPoint's Avatar
Default 5 bolt DP flange on sc61
I was wondering if anyone knows which 5bolt flange is compatible with the Precision SC61 turbo. I asked kteller and exploitedracing about the ones that they sell but they are not sure. I havent had time to get some measurements of the bolt holes to compare.
thanks
William
Old Dec 16, 2004 | 10:50 AM
lysergican's Avatar
Default Re: 5 bolt DP flange on sc61 (TeamShiftPoint)
i have this adapter on my sc61.
http://www.atpturbo.com/Mercha...e=FLS
i think any t3 5 bolt flange should work.
Old Dec 16, 2004 | 10:51 AM
VTC_CiViC's Avatar
Default Re: 5 bolt DP flange on sc61 (macroresin)
They don't use special flanges, a standard T3 5-bolt is all you need
Old Dec 16, 2004 | 11:11 AM
TurboTegB18c's Avatar
Default Re: 5 bolt DP flange on sc61 (VTC_resurected_CiViC)
Just make sure u grind out the opening on the flange to match the sc61. The outlet diameter is around 2.75 i belive and most flanges are 2.5
Rod.'s Avatar
you need a flange that fits a .63 ar exhaust side?
error
Feb 5, 2007 08:41 PM
Hump-Free
Oct 9, 2006 08:54 PM
Jared
Dec 18, 2003 10:31 AM
ID_ten_T
Aug 28, 2003 12:45 PM
