question about 17's on civic
Old Dec 16, 2004 | 05:46 AM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default question about 17's on civic
Ok im new to rims and ****, i'm ridin on some steelies, but might come up on some 17's and im wondering will i need to do anything to the suspension or will it be cool just the way the car is
Old Dec 16, 2004 | 05:50 AM
klungemonger's Avatar
I've used 17" on stock and lowered suspensions it was fine either way.
Old Dec 16, 2004 | 05:51 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (klungemonger)
Yea i would just lower it a little bit. Otherwise your gonna look like a 4x4 lol
Old Dec 16, 2004 | 06:37 AM
punku10's Avatar
Default Re: (JDM_Ej)
as far as drivability you will be fine as long as you get somewhat of a low profile tire.
as far as looks it will be ugly if you don't lower it and most people here will still hate it even if you do lower it
Old Dec 16, 2004 | 03:44 PM
Default Re: (punku10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punku10 &raquo;</TD></TR><TR><TD CLASS="quote">as far as drivability you will be fine as long as you get somewhat of a low profile tire. </TD></TR></TABLE>
thanks for the input, any more suggestions
Old Dec 16, 2004 | 03:52 PM
205/40 tires are the right ones for a 17" wheel, although they are larger diameter then stock for 92-95 Civics. Perfect size for 96-00 though. You'll be fine anyways, no worries, try using an Eibach ProKit, like 1.3" drop and smooth riding.
Most people these days can't get enough of tiny wheels, which is fine they are usually light and help you accelerate a little quicker. I sold my 17", got 15" but I got tired of the 15" thing and just ended up with lightweight 17" again.
Old Dec 16, 2004 | 03:54 PM
green-'s Avatar
Default Re: question about 17's on civic (Evolution-93-Ex)
Use a 205-40 tire and you should be fine. Is your suspension stock?
SILVER97EX's Avatar
17"s are cool, you won't have a problem with rubbing if you get the correct tire like stated above, i have 17's on my 97 ex with 205/35 tires. work great. just need to lower it a bit now.
Old Dec 16, 2004 | 03:57 PM
sockvtec's Avatar
as far as looks it will be ugly if you don't lower it and most people here will still hate it even if you do lower it </TD></TR></TABLE>
yea hes right, you will definatly be in offroad mode without lowering it...i have 205/40/17 on my hatch and i have a 3.5" drop all the way around on coilovers and it looks really good....and BTW noone should hate it unless you screw up lowering it and make it ugly, or they **** monkeys
Old Dec 16, 2004 | 04:19 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">I've used 17" on stock and lowered suspensions it was fine either way.</TD></TR></TABLE>
Old Dec 17, 2004 | 06:33 AM
Default Re: question about 17's on civic (green00EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green00EX &raquo;</TD></TR><TR><TD CLASS="quote">Use a 205-40 tire and you should be fine. Is your suspension stock? </TD></TR></TABLE>
yea its stock, so 17's on stock is ok with low profile tires
Old Dec 17, 2004 | 06:38 AM
smithenhiven's Avatar
11:11
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evolution-93-Ex &raquo;</TD></TR><TR><TD CLASS="quote">yea its stock, so 17's on stock is ok with low profile tires </TD></TR></TABLE>
Yes, if you live in an area that has perfect roads, meaning ABSOLUTELY NO POTHOLES/IMPERFECTIONS. I had 17's on my civic, and trust me, you'll feel every little bump.
Old Dec 17, 2004 | 08:16 AM
Sour Diesel's Avatar
It will be fine, just get the correct tire size and offset so you don't rub. Personally I wouldn't go over 16's on a civic, and if it was my civic I would go with 15's.
Old Dec 20, 2004 | 07:44 PM
my lil hatchie's Avatar
u should lower it a little it would look better
Old Dec 20, 2004 | 08:35 PM
ftwlucky13's Avatar
I would say expect to lose acceleration.
My car is a lot quicker with the stock wheels on then the 17's
Old Dec 20, 2004 | 08:38 PM
tw_itr01's Avatar
Default Re: question about 17's on civic (my lil hatchie)
my girl has a 95 civic with 17's on it and she has no problems with them. Does anyone know the best springs to put on it because it looks kinda high. She doesn't want it slammed since she uses it everyday but a nice drop is what she wants.
Old Dec 20, 2004 | 08:44 PM
ftwlucky13's Avatar
Tein S. Tech
You can get them for about $130 shipped off of e-bay.
I was going to go for the Eibach pro-kit springs, but i'm glad I didn't because with the Tein's you get a little more drop, but it's not enough to the point you have to worry about scrapping or rubbing at all. Only thing that scrapes a tiny bit once in a while is my muffler on my Tanabe cat-back. It hangs very low.
Other than that it's a good stance. It's 1.8" in the front and 1.7" in the back for 92-95 civics.
Old Dec 20, 2004 | 10:18 PM
red91sit's Avatar
Default Re: (ftwlucky13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ftwlucky13 &raquo;</TD></TR><TR><TD CLASS="quote">Tein S. Tech
It's 1.8" in the front and 1.7" in the back for 92-95 civics.</TD></TR></TABLE>
How's the handling with those springs? pretty neutral? still pushes? or oversteer?
Old Dec 21, 2004 | 12:01 AM
jonjon149's Avatar
I just sold a 94 civ 4dr with 18 konigs and it looked sick because it was sitting on the lip of the rims it rubbed a little when you turning but it was not for the begginer. If you lower your car, consider ride quality as well, I sell tuner cars, honda/acuras only. all my cars are lowered ( the wright way) when i sell them they look like german turing cars. The more its slamed, the better it looks but the worse it rides. IF you dont know how to drive a lowered car very well dont go to low because you wont even know how to get in your local Mcdonalds with out ripping your fenders out.
Old Dec 21, 2004 | 06:49 PM
ftwlucky13's Avatar
As far as handling they are definitly a big imrovement over stock. A lot less body roll & dive & squat. They also aren't extremely stiff, which I like because I don't do any serious cornering like auto-x or anything. So basically you will still have a smooth ride, but get the benefits of a lowered center of gravity.
JVDE
Oct 22, 2008 05:06 PM
ApolloSpeed
Aug 30, 2005 11:16 AM
ocdcivic
11
Feb 7, 2005 06:39 PM
all2nv
May 25, 2004 06:50 AM
RedLinin247
Jun 24, 2003 04:09 PM
