spun a bearing
Old Dec 16, 2004 | 12:24 AM
99EletronblueSI's Avatar
Default spun a bearing
how the heck you know : when a motor spun a bearing ? cause I am going to buy a used block ,.and how can you tell it works fine?
Old Dec 16, 2004 | 03:53 AM
civic-4-ges's Avatar
Default Re: spun a bearing (99EletronblueSI)
If it turns over, chances are you don't have a spun bearing
If you turn it over, you might be able to "hear" the bearing griding if it has just spun, however there really is no 100% way to be sure without taking the oil pan off and the rod caps and checking yourself.
Is this really an all motor forum question?
Old Dec 16, 2004 | 09:36 AM
jdm123's Avatar
Default Re: spun a bearing (civic-4-ges)
when you have the crank out and everything what is the main thing you should look for to see if it's spun or not?
Old Dec 16, 2004 | 10:00 AM
Default Re: spun a bearing (jdm123)
2 bearing halves together!
Modified by civic-4-ges at 4:26 PM 12/16/2004
Old Dec 16, 2004 | 01:38 PM
99 TYPE R's Avatar
how much r u buyin the block for because i have 1 for sale that does not have anything wrong with it i took outta my 99 si , it has 63k on it let me know
Fishy_hondaman
Engine Machining & Assembly
Sep 18, 2016 10:05 PM
SurferDude905
Jun 29, 2009 04:30 AM
SuckMyDOHC
Jun 15, 2008 11:29 AM
Supra
May 2, 2004 06:37 PM
carblegal
Jul 2, 2003 07:32 PM
