CRX DX ---> CRX Si
I just bought a little project CRX on the side. Its the DX model. The difference between the DX and SI is the engine and transmission. Ive been reading up on the DOHC ZC swaps. For the ZC swap you need to switch dpfi to mpfi if your working with a DX. To put a stock Si engine into my DX do I still have to go through all that process?
no..You can use your dpfi manifold on the si motor..But thats stupid..
And the motor will not be used to its full potential
Just convert to mpfi and get it over with now..
Alot better then dpfi
From: I told you to wait in the truck in Texas, United States
Yes,you just have to get an intake manifold,
resistor box and injector clips,and its wiring from a D16a6..
[Look in the FAQ section at the top of this forum for links]
HottCRXracer
Feb 26, 2002 05:59 AM
