Considering OBDIIb-OBD1 conversion but have questions!
Old Dec 15, 2004 | 08:16 PM
BeerBaron105's Avatar
Default Considering OBDIIb-OBD1 conversion but have questions!
Hey
As some of you know i have a obdIIb 99 SiR in my 99 dx hatch, ive been contemplating converting to OBD1 for several reasons but i have some questions
Is it as simple as finding for example, a chipped p28, using a obd2b-obd1 conversion harness, then plugging it in the middle, do i have to alter the harness in any way?
what impact will this have on my OBD2 engine diagnnostics or sensors, i know i will lose the secondary o2 but is that it?
Any insight?
Old Dec 15, 2004 | 08:37 PM
Ivan's Avatar
senior gold member
Default Re: Considering OBDIIb-OBD1 conversion but have questions! (BeerBaron105)
I ran one in one of my old cars. I just plugged in the harness and the chipped ecu and that was it. I didn't have to rewire anything.
Old Dec 15, 2004 | 09:02 PM
ABK's Avatar
ABK
Default Re: Considering OBDIIb-OBD1 conversion but have questions! (Ivan)
OBD 2 diagnostic port will not work
Old Dec 15, 2004 | 09:05 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Considering OBDIIb-OBD1 conversion but have questions! (ABK)
It's a simple switch with a conversion harness and chipped ecu. You will loose the secondary O2 sensor like you said and the OBD2 diagnostic port as was said above. Depending on the ecu you get you may lose the knock sensor as well if you use a P28.
Old Dec 15, 2004 | 09:16 PM
whos ever used the diagnostic port anyways
i just do the old paper clip in that little plug trick
Old Dec 15, 2004 | 09:28 PM
ABK's Avatar
ABK
Default Re: (BeerBaron105)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerBaron105 &raquo;</TD></TR><TR><TD CLASS="quote">whos ever used the diagnostic port anyways
i just do the old paper clip in that little plug trick</TD></TR></TABLE>
well those people (which I hate so much) that work for the goverment and check you damn emissions.
Old Dec 15, 2004 | 09:35 PM
true, but i know a couple places to get "legit" e-tests done.... lol
Old Dec 16, 2004 | 08:28 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">
well those people (which I hate so much) that work for the goverment and check you damn emissions.</TD></TR></TABLE>
Actually that's one thing I forgot to mention, converting to OBD 1 from OBD 2 isn't legal to do as far as emissions go if you live in an area where that testing is done. You'll have to convert it back to OBD 2 when it's time to get your emissions testing done again which should be easy, unless you know someone that can "help you out".
Old Dec 16, 2004 | 08:31 AM
ABK's Avatar
ABK
Default Re: (00Red_SiR)
but if you boosting and your rely on obdI ecu as your tunning, removing it would cause death to your motor.
Old Dec 16, 2004 | 08:35 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">but if you boosting and your rely on obdI ecu as your tunning, removing it would cause death to your motor.</TD></TR></TABLE>
Yes this is true, I was assuming the setup was all motor. Going back to OBD 1 with a boosted car may not kill it while it's being tested for emissions but it would probably make it run so crappy that it would fail badly anyway.
RudeLude
Jun 1, 2006 05:27 AM
OMG B16
Dec 28, 2004 01:07 AM
CRXLST
13
Sep 25, 2004 07:32 PM
1991hondahead
May 7, 2004 03:29 PM
ElectronMan
Jun 14, 2002 06:49 PM
