b16 wont start, help!
Old Dec 15, 2004 | 07:51 PM
sk8rmike's Avatar
Default b16 wont start, help!
i just swapped a b16 into my del sol. cam timing is good, i used an ex wiring harness and pretty much everything was plug and play. the problem im having is the damn thing cranks but wont start up. it's getting fuel but a really weak spark. i swapped the guts out of my single cam dizzy and it was the same. i swapped my friends gsr dizzy onto my car and it was the same. i know the ecu is good as well. is this most likely because of a bad ground? any other thoughts on what might be causing the problem?
Old Dec 15, 2004 | 09:20 PM
Mike@K-Tuned's Avatar
Default Re: b16 wont start, help! (sk8rmike)
There is a chance of the problem being a bad ground. My grounds, located on the thermostat housing came loose once and my car wouldn't start. Check that the four wires grounded to the thermostat housing by a 10mm bolt aren't loose or corroded. Also, why didn't you use your existing del sol harness? When I do this B16 swap I use the del sol engine harness. Just curious why you changed it?Good luck
Old Dec 16, 2004 | 03:40 AM
sk8rmike's Avatar
Default Re: b16 wont start, help! (EGgsrAM)
i did use my existing harness. i was just letting everyone know i used a harness already wired for VTEC. i'll check that ground though as i did have to mess w/ the Tstat housing right before i dropped the motor in.
Old Dec 16, 2004 | 03:48 PM
Another thing I thought you might wanna check cause you said weak spark. Check for proper voltage to your ignition coil (blk/yellow wire if I remember right)Verify with Helms.
Old Dec 16, 2004 | 05:45 PM
UncleD's Avatar
Maybe check your plug wires, check your plugs and see if their dirty or not. If the plugs are black then they sometimes won't fire. Maybe swap the igniter for a different one. Are the spark plug wires in the correct firing order, 1342?
Old Dec 16, 2004 | 06:45 PM
sk8rmike's Avatar
Default Re: b16 wont start, help! (clean rice)
plugs are brand new ngk's. firing order was right and the guts are all out of a known working distributor. i think i am going to get a new set of plug wires and go over some of the wiring in the harness.
SIR2DelSol
Jun 15, 2005 09:59 AM
Sonik_fury
May 31, 2005 06:21 PM
sk8rmike
Dec 15, 2004 08:16 PM
noslude93
Mar 7, 2004 06:28 PM
DragII
Nov 26, 2001 10:38 AM
