replacing internals for a distributor
Old Dec 15, 2004 | 07:04 PM
boi_si's Avatar
Default replacing internals for a distributor
i have a dead distributor. i dont know which to change out. which part usually dies out when the distributor goes out? the ignitor or the coil??
why im asking is because i dont want to buy a piece which will tell me that the other piece is the failed one. is there a way to test?
Old Dec 16, 2004 | 11:27 PM
Slain's Avatar
get yourself a helms or borrow one. i believe you test for voltage in both of them. i cant remember off the top of my head
Old Dec 17, 2004 | 06:00 AM
JimBlake's Avatar
Default Re: replacing internals for a distributor (boi_si)
You can test resistance across the 2 circuits of the coil, but that doesn't tell you if either one is shorting to the case. So if the resistance measures bad, you know the coil is bad. If the resistance measures good, then maybe it's still bad...
The Helm book says something about checking ignitors, but I don't remember how.
rollinswapshop
Mar 16, 2011 07:43 PM
ILuvMyJdmDc4
Nov 27, 2007 05:17 AM
Tealeg88
May 7, 2006 09:13 AM
Sinner
Aug 11, 2005 07:59 AM
