Automatic DOHC ZC 2nd GEN
Old Dec 15, 2004 | 06:54 PM
blue_dlb's Avatar
Default Automatic DOHC ZC 2nd GEN
Has anyone done or know someone that has converted their Automatic to ZC while keeping the Auto tranny? Making it a DOHC ZC with an auto tranny. I know it sounds like a big waste of money and time, but this is what I prefered at this point in time.
Thanks for the help.
Old Dec 16, 2004 | 07:01 AM
blue_dlb's Avatar
Default Re: Automatic DOHC ZC 2nd GEN (blue_dlb)
Where are the experts and critics!!!
Old Dec 16, 2004 | 07:03 AM
ian.'s Avatar
ef forum would work better for you
Old Dec 16, 2004 | 11:25 AM
Fate's Avatar
Default Re: Automatic DOHC ZC 2nd GEN (IC33)
the ZC is DOHC and you can get a auto w/ it? Please explain your question.
Old Dec 16, 2004 | 11:38 AM
rodrez.'s Avatar
What car is this going into? What's in there now?
Old Dec 16, 2004 | 12:41 PM
blue_dlb's Avatar
Okay let me make it clear for you guys. I have a 92 DX auto hatch. I want to swap out the motor only and put in a 2nd Gen ZC JDM 92-95 civic OBI MOTOR only. The reason why I want this is because I have to commute in traffic and do not want a stick shift right now. I want just a bit of power so i can jump if i needed to. SO basically the same power as an LS motor auto but in a civic hatch. Get it now??? Also it won't be in the EF forum becuase my car is 92 and the motor is also 92-95 DOHC ZC which most people didn't know exist, so this is the right forum.
Old Dec 16, 2004 | 05:24 PM
blue_dlb's Avatar
up agian.
Old Dec 16, 2004 | 08:30 PM
homeskillet's Avatar
everything should go great... i dont see your problem. they are both d series... either ecu would work.. either tranny would work. just put it in and drive it... i dont see point in asking if anyone else has done it. do it.
Old Dec 16, 2004 | 09:06 PM
krazyDOHC's Avatar
Default Re: (homeskillet)
the dohc zc bolted right up to my ex/si tranny and ran pretty good in my hatch, im assuming you wont have any problems...as long as you use your current clutch pack (or whatever they call it for automatics)
and btw...it wont be THAT much faster...the dohc zc is still just a 1.6
Old Dec 16, 2004 | 09:08 PM
rodrez.'s Avatar
Default Re: (krazySOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazySOHC &raquo;</TD></TR><TR><TD CLASS="quote">
and btw...it wont be THAT much faster...the dohc zc is still just a 1.6 </TD></TR></TABLE>
Good point. The difference in power won't be big.
Old Dec 16, 2004 | 09:17 PM
_Cyclone_'s Avatar
It probably won't make a big enough difference to justify spending the money on a new engine... unless you have it already or are getting it really cheap, that's different. I doubt you'd notice the difference until you were on the highway, but like krazySOHC said, it won't be major.
Old Dec 17, 2004 | 01:35 PM
20 hp is quite a difference i would say. its like saying swapping to an ls motor is nothing.. i say go ahead and do it, then gte a beater and put an ex/si tranny with the zc and ull have a quick little car. but that is a waste of time though pulling ur engine and stuff for an auto.
Old Dec 19, 2004 | 09:24 AM
blue_dlb's Avatar
my current engine has over 315K miles. HONDA POWER BABEE. It runs fine even with the AC on. the problem is that the water pump seals are bad and is leaking fluid from it. If i change the waterpump, i might as well change the timming belt. That's gonna be well over a hundred bucks. A DOHC ZC motor is like 4-5 hundred bucks so might as well swap out the engine. I just need to know what kinda things I need for this swap. LIke can i still us my auto dx ecu or get an LS. I need technical stuff like that.
Old Dec 19, 2004 | 11:37 AM
u can still use your dx ecu, but i suggest using the zc ecu.. i dont know how big of a difference there would be, but the ecu should be with the engine you buy im guessing. u dont really need anything besides coolant, oil change and tune up is a good idea. otherwise just drop it on in.
Old Dec 19, 2004 | 02:29 PM
krazyDOHC's Avatar
ive had several different kinds of d series motors in my car and i can honestly tell you...it wont be a HUGE difference...especially if you have an auto...with a simple intake, ex header and intake manifold (under 100 bucs) youll be pretty close to a dohc zc...i speak from experience
if you have the zc laying around like i did....go for it
Old Jan 24, 2015 | 04:24 AM
Eh2Guanaco's Avatar
Like everyone else said on here...If you have it handy or not paying much for it...then go for it...it'll be pretty pointless though with an auto...unique but pointless...if you want to see a real difference...make it manual and drop a combo of a ex/si tranny and the zc and then you'll have a real difference not a super car but enough "upgrade" from what you have now
Old Jan 24, 2015 | 04:42 AM
Eh2Guanaco's Avatar
OHH ITS A OLD THREAD HAHA
the king.
Dec 11, 2006 08:25 PM
92hatchling
Feb 6, 2006 06:10 PM
SkankyEJ7
Nov 28, 2004 10:23 AM
speedy-crx
Oct 2, 2002 05:49 PM
mugen89
Sep 29, 2002 04:41 PM
