whats the diff in 50 mm performance???
okay im wondering what is the difference in using a 50mm tial BOV vs. a smaller bov such as a greddy type s or some where around those lines?
When you're pushing a lot more boost or if you're on a larger motor the smaller BOV's will hit a point where they simply can not flow any more air, and will cause compressor surge. A larger and better flowing BOV like the Tial will eventually reach this point too, but you will have to push a lot more boost/airflow through it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this guy 2fast »</TD></TR><TR><TD CLASS="quote">what if you are pushing a minimum amount of boost will it affect it still </TD></TR></TABLE>
? Think of the BOV in the same context as an exhaust system. A Larger exhaust will support a higher level of horsepower than a smaller exhaust, but the large exhaust will still do perfectly fine at lower boost and horsepower levels. Same thing with a BOV. Larger means it can handle more boost and airflow, but it will still do fine on a stock motor setup. I have a Tial BOV on my setup and I was running a stock block LS/VTEC at 7-8 psi for a while.
