Quick HELP!!!! My axle poped out when doing my suspension!!!!
Old Dec 15, 2004 | 03:03 PM
integraautox's Avatar
Default Quick HELP!!!! My axle poped out when doing my suspension!!!!
ok so I was doing the front driver side spring and when I took it out the axle boot that connect to the tranny is locked in place. How in gods name do I fix this? Do I have to completly take out my axle to do this. My car is stuck sitting in my garage so please help me.
Old Dec 15, 2004 | 04:33 PM
dacaveman's Avatar
Try to get it back in there. Same thing happend to me and my friend when were lowering his integra. We working on it for hours and hours just wouldn't go in so we finally just towed it to a shop they fixed it for like 180 dollars.
Old Dec 15, 2004 | 06:01 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Quick HELP!!!! My axle poped out when doing my suspension!!!! (integraautox)
Search. This problem is all over the net because it happens to everyone it seems.
I can't exactly remember, but I think you need to put the car in gear and rotate the rotor back and forth until the axle slides back in. Been awhile since I've had to do this.
Old Dec 15, 2004 | 09:05 PM
triple_s1x's Avatar
Default Re: Quick HELP!!!! My axle poped out when doing my suspension!!!! (Todd00)
Yeah you basically have to get the splines to match up, and it will slide right in.
Old Dec 15, 2004 | 10:42 PM
ludeR917's Avatar
we pushed it in as far as we can and i held it there while my friend kicked it. hey, it works
Old Dec 16, 2004 | 09:18 AM
Default Re: Quick HELP!!!! My axle poped out when doing my suspension!!!! (ludeR917)
alright well I did it the hard way and messy way. I just took the CV boot off and realigned the knuckles and slide them back into place. then regreased it and tied the boot back down. God doing the springs on an RSX was so much harder then any civic or integra I have done. **** my tranny swaps were easier then this. Oh well I got the two fronts done hopefully the rears will be smooth sailing. THanks guys.
Old Dec 16, 2004 | 09:32 AM
Blue_Si03's Avatar
You don't really have to worry about the rears. It would have been a lot easier if you held up the axles so they wouldn't have fallen. I've learned from this so when I redo my suspension it won't take me as long.
Old Dec 17, 2004 | 05:43 PM
PhunDrm's Avatar
Happened to me a couple of times during my nightmarish suspension experience. I had to do my suspension 3 times. I pretty much just rotated the axle back and forth with the rotor until it slid in.
Old Dec 17, 2004 | 07:01 PM
George Knighton's Avatar
H-T Order of Merit
Seems like this has happened to all of us.
Old Dec 17, 2004 | 08:18 PM
Default Re: (George Knighton)
yeah I just got the rears done today and they maybe took me 1 hour for both of them. So it was a total of about 8-9 hours for the two fronts including the driving back and forth to get parts to clamp the CV joint boots together. In the long run it was well worth it. My car looks sweet and handels a lot better.
jdm96gsr
Nov 21, 2010 08:24 PM
wu tang
14
Dec 17, 2007 09:23 AM
killakalipoph
Honda Fit
Nov 29, 2007 10:16 PM
JSpin
Mar 26, 2004 08:52 PM
