B16 Full Engine....Constructive Critiscism
Well here it is...I want to swap a b16 into my civic and do a build....here's my parts list. What do you guys think?
Head-
P&P
Comb. Chamber match to bore
3 angle
Dual Springs/Titanium Rockers
Stainless Valves
Skunk 2 Stage 2's
Block-
Bored and sleeved to 85mm
Wiseco pistons 11:1
Rods...Crower?....not sure yet
Knife-edge, lighten, balance etc. crank
Bigger oilpan
Drivetrain-
Not fully decided on tranny
Clutchmasters Clutch kit(Still in debate which stage)
10 lb or so chromoly flywheel
And definately hondata with slightly bigger injectors and fuel pump.
Probly missed 1 or 2 things but there it is. Also if my block is sleeved could i reliably go bigger with the bore??
Thanks in advance for any input
Head-
P&P
3 angle
Stainless Valves
Skunk 2 Stage 2's
Block-
Wiseco pistons 11:1
Bigger oilpan
Drivetrain-
Your head as pretty much have everything....
Your block...For rods----eagles....
For your oil pan make sure you get a badass oil pickup...
Drivetrain....
Ys1 tranny--gsr geared...
7lb flywheel....
clutchmaster- don't go for stage 2 all i hear is bad stuff...
Drivetrain....
7lb flywheel....
Dont forget to get a different oil pump gear..Dont wanna starve your engine from oil or shatter the stock unit..
Balance the entire rotating assembly..Vibration kills the motor..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 »</TD></TR><TR><TD CLASS="quote">just buy a type r motor u will be happy.
check the ht sale board for deals
Well I live in nowhere, bc, canada so finding a type-r without paying my left nut would be tough
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude »</TD></TR><TR><TD CLASS="quote">Your head as pretty much have everything....
Any other opinions on rods?
Drivetrain....
7lb flywheel....
I was thinkin of just droppin a stock tranny from something in...maybe even the b16 itself
What stage clutch would you recommend? or better yet...do you have a different brand opinion?
and i definitely momentarily forgot about the oil pump and balancing the asembly...brain fart haha
also like i said....do you think i could reliably bore over 85?
Drivetrain....
7lb flywheel....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riley_rb_34 »</TD></TR><TR><TD CLASS="quote">Block-
Wiseco pistons 11:1
Bigger oilpan</TD></TR></TABLE>
Do this to a b18c.
Wiseco pistons 11:1
Do this to a b18c.
oh right, i forgot the msd ignition and blaster coil...some crazy plugs and wires...probly an upgraded rad....and then susp mods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">
Do this to a b18c.</TD></TR></TABLE>
This goes back to where i live....if i can find one for a decent price then i definitely will....oh the look on the 5.0's face....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">riley_rb_34This goes back to where i live....if i can find one for a decent price then i definitely will....oh the look on the 5.0's face....
They're pretty easy to find in the ht classifieds. When you're a regular member check the classifieds. I bought one.
</TD></TR></TABLE>They're pretty easy to find in the ht classifieds. When you're a regular member check the classifieds. I bought one.
well i'll definitely keep researching....keep saving....keep bothering people with questions....
two more that have no doubt been asked 5 billion times
any estimated whp figures and is 85mm a good size for a sleeved block or could i reliably go bigger
projectef
Sep 8, 2007 01:43 PM
EG-cellent
12
Aug 31, 2004 04:16 AM
