shifter problems
Recently i installed a b&m edge shifter on my 2k gsr. Now i have been noticing a rattling noise coming from under the car when i reach 3500 rpms. I looked all over underneath the car and can't find where the rattling is coming from. The noise is driving me crazy. I remember hearing about something similar to this problem but couldn't come up with anything when i did a search. I also installed a set of energy suspension bushings when i was installing the shifter. But if anyone else has a similar problem or has heard of a solution to this please reply before the noise drives me to insanity. Thanks.
because of the way the B&M edge is made it rattles like that, i have one and i have the Nuespeed shift bushings. mine did the same thing and so did everyone else i know that has one. 2 things you can do, 1) make sure the bolt going through the shifter is tightened all the way down, 2) go get a couple more o-rings and install them next to the other ones on the bolt to give less play. hope that helps
In'tristing...I have a Ractive kit, and it rattles around 3500 rpm as well. It's definitely the shifter-just a sympathetic resonance of some kind. It just happens with some shifters on some cars. I really don't know how to eliminate it. Come spring (when it's warm enough for me to work on the car again
) I'm going to play around with some shims (rubber or polyurethane) to see if I can tighten up the shifter and/or eliminate the rattling noise.
The Integra must just have a resonant point @ 3500 rpm. I wonder if motor mount inserts or shifter stabilizer bushings would change this at all. Prob'ly just make it worse.
) I'm going to play around with some shims (rubber or polyurethane) to see if I can tighten up the shifter and/or eliminate the rattling noise.The Integra must just have a resonant point @ 3500 rpm. I wonder if motor mount inserts or shifter stabilizer bushings would change this at all. Prob'ly just make it worse.
I've heard suggestions that proper tightening and lubrication work wonders. I know for a fact that mine did not buzz for months after it was first installed. When it's warm enough out, I'm going back under the car for another lube and tightening!
Delano5050
11
Aug 20, 2007 12:40 PM
weaselchew
Dec 16, 2002 06:11 AM
