Stupid question: Need install write up for urethanre bushings - 92 Civic hatch...
I did a search ( urethane bushing install ) and found several write-ups on what people think, but found no how-to on the install...
Looking for an easy how-to to pass on regarding the install of a urethane master bushing set for a 92-95 Civic hatch...
Anyone?
Anyone?
Remove suspension peices that need the bushing(s) replaced.
Take them to a shop, along with your bushings and a few $$$, give them all to the shop, come back later and pick them up.
Re-install in reverse order.
And if you're going to do it yourself and don't have a press, burning them out and then using a hack saw to get the outter sleeve (of the bushing) out is one way to go - but at this point, the shop sounds like a much better idea.
Its not brain surgery...
Get a small press from Harbor Frieght like this one http://www.harborfreight.com/c...=1666 . Also get the hardware kit or borrow a ball joint press from the car parts store and use the tube and socket from that.
Remove suspension component and put it on the press.
Press out the old rubber bushing.
Lubricate the new bushing as needed. Press it in.
Sorry no pics.
Sorry no pics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Remove suspension peices that need the bushing(s) replaced.
Really!? Thanks Focker.
As I said, I am looking for a write up to pass along, not for me. Seeing as I work for a dealer, I know how to do it.
Anyone else?
</TD></TR></TABLE>Really!? Thanks Focker.
Anyone else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cynical 1 »</TD></TR><TR><TD CLASS="quote">
Anyone else?</TD></TR></TABLE>
how is a bushing install NOT self-explanatory???????? remove suspension. press 'em out, put back in, reinstall suspension. WOW! ******...............
I kind of don't want to jump in here due to it's already gotten ugly, however;
Why not just tell the guy to look at the instructions that come with the bushings.
Wes
Wes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke »</TD></TR><TR><TD CLASS="quote">
how is a bushing install NOT self-explanatory???????? remove suspension. press 'em out, put back in, reinstall suspension. WOW! ******...............</TD></TR></TABLE>
I know, it was too simple a question to ask the punks on here...
Sorry for trying to help someone out that has never done this before. I was hoping someone intelligent would step in and provide me with a link to a how to to pass on... Guess not.
Thank you HT!
Thank you HT!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cynical 1 »</TD></TR><TR><TD CLASS="quote">Thank you HT! </TD></TR></TABLE>
You're Welcome....******!
Its so gawd-damn easy to do this, who in the hell needs a write-up? Does your 'friend' need a write-up on changing oil, perhaps rotating his tires?? You work for a dealer yet YOU can't help him out - I mean, if you know how easy this is, why not just explain that to him??
Sounds like maybe you and your friend are the same person.
Sounds like maybe you and your friend are the same person. </TD></TR></TABLE>
No. we're not the same. I have urethane bushings on my car.
So, why did you turn this into a pissing match with a smart *** comment? I was looking for help, not criticizm. Nothing to say, then **** off and let someone else answer.
I reported this to a moderator, we'll see if anything happens. Doubtful...
NeedACivic
Sep 7, 2003 08:39 PM
