Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
? about spring rates.
Old Dec 15, 2004 | 01:58 PM
E V I A N's Avatar
Default ? about spring rates.
I have seen alot of people go with a higher spring rate in the rear compared to the front. I was wondering why alot of people are doing that when all the coilover kits have a higher spring rate in the front. Can anyone tell me why this is.
Thanks for the help.
Old Dec 15, 2004 | 02:03 PM
artifex's Avatar
say it
Default Re: ? about spring rates. (E V I A N)
https://honda-tech.com/zerosearch
Old Dec 15, 2004 | 02:05 PM
nsxjr2's Avatar
Default Re: ? about spring rates. (artifex)
Here you go
https://honda-tech.com/zerothread?id=285747
Old Dec 15, 2004 | 03:13 PM
.RJ's Avatar
.RJ
Default Re: ? about spring rates. (nsxjr2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxjr2 &raquo;</TD></TR><TR><TD CLASS="quote">Here you go
https://honda-tech.com/zerothread?id=285747</TD></TR></TABLE>
Wow, thats in the forum faq... imagine that
Old Dec 16, 2004 | 03:06 AM
E V I A N's Avatar
Default Re: ? about spring rates. (.RJ)
Hey thanks guys i read the faq and i really dont understand it can you say it in lamons term for me.
Old Dec 16, 2004 | 04:44 AM
Solracer's Avatar
FWD hondas tend to understeer (push) with a stock setup it is safer on the street, and most aftermarket coil-over kits reflect that. When you increase the spring rate on one end of the car you are increasing grip on the other end. So if a car is already understeering fwd car, increasing the spring rates in the rear is going to fix that condition So too get more grip on the front end you increase the spring rate in the rear, this makes the car want to understeer less and the rear to rotate better/faster, which of course makes the car loose and can be a handfull to drive if you aren't carefull or experienced. For a car that is never going to auto-x hpde'd or raced having a car that has more spring rate in the front is safer and what I would recomend for most people on the street.
Modified by Solracer at 1:08 PM 12/16/2004
Modified by Solracer at 1:09 PM 12/16/2004
Old Dec 16, 2004 | 06:04 AM
Blue Si #72's Avatar
Default Re: ? about spring rates. (Solracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">FWD hondas tend to understeer (push) with a stock setup it is safer on the street, and most aftermarket coil-over kits reflect that. When you increase the spring rate on one end of the car you are increasing grip on the other end. So if a car is already understeering fwd car, increasing the spring rates in the rear are just going to fix that condition. so to get more grip on the front end you increase the spring rate in the rear, this makes the car want to understeer less and the rear to rotate better/faster, which of course makes the car loose and can be a handfull to drive if you aren't carefull or experienced. For a car that is never going to auto-x hpde'd or raced having a car that has more spring rate in the front is safer and what I would recomend for most people on the street.</TD></TR></TABLE>
Fixed
Old Dec 16, 2004 | 09:08 AM
Solracer's Avatar
Default Re: ? about spring rates. (Blue Si #72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue Si #72 &raquo;</TD></TR><TR><TD CLASS="quote">
Fixed</TD></TR></TABLE>
Doh! I fixed my post with your corrections.. Thanks!
The Jacko
Suspension & Brakes
Jan 31, 2006 01:44 PM
UltimX
Suspension & Brakes
Aug 30, 2005 08:37 AM
mountaindewguy
Suspension & Brakes
Feb 24, 2005 02:17 PM
kndaqikEG
14
Dec 31, 2004 08:54 AM
DIRep972
Jan 5, 2004 05:02 AM
