H22 Turbo Kit on H23 motor....possible?
Anyone out there know if an H22 turbo kit will work with an H23 motor? I know the Exhaust manifold holes arent the same between the two but if I swapped out for ran h23 manifold would it work properly?
The reason Im looking towards this idea is because the H22 Turbo Kits are all over ebay for reasonable prices...
Thanks
Thanks
the h23 and h22 heads are different,
if you buy a h22 turbo kit, then you will need to find the exact same header that the h22 kit uses as the h23 and buy the h23 header from some where,
also don't quote me on this but i belive the h23 head sits alittle lower than the h22, s if you did buy an h22 kit then some how found a h23 header ment for that kit, the downpipe might be to long/short.
Ok, then just get the H22 kit and buy a seperate H23 manifold.
Horsepowerfreaks.com sells them--http://horsepowerfreaks.com/vi....html
I bought Drag turbo kits for my H23 powered 90 Accord, and then I used that all the turbo kits part form the H23 to my H22 powered 93 Prelude, except the turbo manifold which I bought separate for the H22.
I got Drag H23 cast iron turbo manifold for SELL if you are interested.
See pictures in my site........................................
